frebel Guest
Posted: Fri Feb 15, 2002 10:41 am Post subject: |
Hello
INFO...1978 924 4 speed tranny
I am looking for estimated tranny re-build cost from best case to worst case...In Canadian funds please.
Thanx in advance for your time and advice
Dave |
Vince Ponz Guest
Posted: Fri Feb 15, 2002 11:31 am Post subject: |
| I have a 4 speed for you cheap. I have a good torque tube too. Let me know. |
dwak Guest
Posted: Fri Feb 15, 2002 11:33 am Post subject: |
Dave,
I could have an excellent '78 4 spd for sale if I turn my '78 into a '79 and I'm in eastern Ontario. Where are you?
dwak
dwak Guest
Posted: Fri Feb 15, 2002 11:34 am Post subject: |
Damn, you're fast Vince!
dwak du bois
[ This Message was edited by: dwak on 2002-02-15 12:35 ] |
JvGinPDX Guest
Posted: Fri Feb 15, 2002 11:57 am Post subject: |
| The first question I have is: How is your car acting up? I thought I had a bad trans in my 77 924, but the howling I heard turned out to be bad bearings in the torque tube, and the binding and vibration I experienced turned out to be a bad CV joint, the trans was still good. I have seen rebuilt trans units in the aftermarket publications, they charge about 1500 US, which is close to what a 924 in good condition would sell for. Junkyards in Portland Oregon charge 200 to 250 for a 4 speed trans. CDN would be a third higher I suppose. I understand that the 4 speeds last a long time, so your best bet might be a junk yard, or someone on this board. I have a trans from a 78 I did not need, if you are interested. |
Posted: Fri Feb 15, 2002 12:15 pm Post subject: |
don't even think about rebuilding a 4-speed.
They are almost indestructable especially when sitting behind a US-spec 924 so check the stuff that JvGinPDX mentioned before assuming it's your trannie.
If it really is dead then it would be a good time to swap in an Audi 5-speed. Check the Wanted/For Sale forum to get an idea of what the guys are selling them for. You want the Audi not the Porsche trans. |
mdaniel83 Guest
Posted: Fri Feb 15, 2002 2:18 pm Post subject: |
| hey guys, what could be wrong when you put it in neutral and just pull it side to side and you can hear it clinking? |
Joes924 Guest
Posted: Fri Feb 15, 2002 4:04 pm Post subject: |
Im waiting till spring to do the adjusting thing, 1 st is just binding a bit.. Ill
explain if I stop and start off when i go to 1 st before i go some time it wont go and i push the clutch a little or just pull and it binds then goes in 2nd fine is it bad to take off in 2nd I up the rpms a bit and it takes off like a rally car ..Ive been usen
that msd rev limiter I have it set at 6000
rpm it works to.. can you grease these torque tube bearings.
JvGinPDX Guest
Posted: Sat Feb 16, 2002 8:42 am Post subject: |
| Joe, the torque tube bearings cannot be greased. When they die, they make a lot of noise. To change them, you need to drop the trans and the rear axle assembly. Once you have the tube loose, the worst is over. There is a proceedure for this in the technical section. Peace and quiet instead of howling at idle and at speed make it all worth it. |
JvGinPDX Guest
Posted: Sun Feb 17, 2002 6:20 am Post subject: |
| I forgot to mention that the bearings for the torque tube cost me all of 50 dollars for the bearings, and 20 dollars in labor for the machine shop to remove and install the bearings in their 4 holders. The cost is not bad, but the job is a PITA. Some beers make it go less painfully. A good time to do this is when you are pulling the trans or the rear end for some other reason. Clutch time would be ideal. |
Joes924 Guest
Posted: Sun Feb 17, 2002 7:10 am Post subject: |
| yea thankyou |
JvGinPDX Guest
Posted: Sun Feb 17, 2002 7:49 am Post subject: |
| Joe, if you are going to rebuild the torque tube, I have some hints for you. I can be reached at JvGinPDX@earthlink.com I have some improvments on the proceedure that make it go easier. I reassembled mine vertically while standing on a ladder. E mail me for the details. |
Posted: Sun Feb 17, 2002 10:10 am Post subject: |
| JvGinPDX perhaps you could share your procedure with all of us by sending the details to Vaughan. |
Vince Ponz Guest
Posted: Sun Feb 17, 2002 10:32 am Post subject: |
| Dwak you are the second one to tell me I am fast. My wife said I was a lousy lover and I said how can she tell in 30 seconds. |
frebel Guest
Posted: Sun Feb 17, 2002 6:17 pm Post subject: |
What do these replys got to do with my ORIGINAL question about rebuild costs guys????
I think ya went way off topic don't you. |
