Joes924 Guest
Posted: Sat Feb 16, 2002 4:21 am Post subject: |
jc whitnets restore everthing auto book
has 4 or 5 heaters in differant sizes some come with ducts and some dont
Iguess Im leading up to the point being
Id want mine all filled glove box heater the works plastic board[it has a name] they use in commercial kitchens and bathrooms cut to
size then filled and smoothed would work if
not on the clove compartment door though
what does a 924 owner put in there anyway .
tapes, a brush,regi,insurance.throw the brush in the back put the tapes, cds ect. on the floor or door panels . I keep my personnel stuff in a note book |
Alex Roy Guest
Posted: Sat Feb 16, 2002 5:30 am Post subject: |
Joe, you may want to wait for the 2nd dash I am going to be making. This is just the stock replacement one, I am going to use this mold to make stock style replacements, and also to make a plaster copy to modify to make a 2nd dash with modern styling and no glove box, heater vents or center console (more of a race style one, closer to the style of the newer 944 dash, but more radical than that).
Joes924 Guest
Posted: Sat Feb 16, 2002 12:20 pm Post subject: |
Man the weather was nice today.. I watched a show here around 5:00pm and it was showing how they made the molds for prototype 1963 stringrayvette and mated it to whats called a bird nest steel frame .. it was neat
wdb Guest
Posted: Sat Feb 16, 2002 10:51 pm Post subject: |
[ This Message was edited by: wdb on 2002-02-22 13:48 ] |
Joes924 Guest
Posted: Sun Feb 17, 2002 6:43 am Post subject: |
I was gonna yesterday,I dont want to hear it
guys
ill leave and never share here again, just
joking |
Guest
Posted: Sun Feb 17, 2002 7:36 am Post subject: |
I keep double clicking on the switch.... nothing happens. Is there violin music as well.
Joes924 Guest
Posted: Fri Feb 22, 2002 12:25 pm Post subject: |
Im doing some work at enchanted forest here out side of salem right off the freeway
I talked to the owner whos a good friend abour fiberglass for awhile so how did you get the acrolite to bend to the contour of the roof
[ This Message was edited by: Joes924 on 2002-03-01 17:38 ] |
Alex Roy Guest
Posted: Fri Feb 22, 2002 3:02 pm Post subject: |
I used my oven. I put half of it in at a time and clamped it down while it cooled. I am also going to weld up a light aluminum frame so it will be semi-removable.
wdb Guest
Posted: Fri Feb 22, 2002 11:23 pm Post subject: |
| did I miss something,what is the acrolite being used for? |
Alex Roy Guest
Posted: Sat Feb 23, 2002 2:16 am Post subject: |
WDB, check out my website, I am using it for the sunroof (to save a couple of #'s and so I can see the sky).
wdb Guest
Posted: Sat Feb 23, 2002 3:08 am Post subject: |
looks cool,fits perfect,well was it hard to do,how did you make the template ,how is it attached,did it stink up the house like burning plastic,will plexi hatchback and side windows be next.you'd need a bigger over for the hatchback, a suggestion: you can buy the parts to a gas bar-b-que grill, burner, hoses,thermostst controled valves,if your thinking about making a angle iron framed,fiberglass insulated,corregated sheet metal oven. I wanna play with this stuff  |
Alex Roy Guest
Posted: Sat Feb 23, 2002 3:54 am Post subject: |
Plexiglass (acrilite) only stinks if you burn it, otherwise it is totally odorless. It takes about 250 degrees and 5-10 minutes to get it pliable, then you have to hold it in the form you want it until it has cooled. You would need pretty extensive heating facilities to make a rear hatch though, I would suspect it is worth it to buy one for $500 for the trouble it would be to make one.
Joes924 Guest
Posted: Sat Feb 23, 2002 12:28 pm Post subject: |
I got to come and see you sometime really ive been thinken of popen bye ..I want to see your dash..I hope you can get the roof to seal.. how or where are all the nuts to the dashboard?.let me put it a other way is the dash easy to take out..
[ This Message was edited by: Joes924 on 2002-02-23 13:31 ]
[ This Message was edited by: Joes924 on 2002-02-25 14:45 ] |
Joes924 Guest
Posted: Fri Mar 01, 2002 4:41 pm Post subject: |
Man speed vision is really changed it was posted awhile ago its goin nascar thats all I see there anymore
Joes924 Guest
Posted: Sun Mar 03, 2002 4:15 pm Post subject: |
so what did you prep the stock dash with ..
Im gonna make my own.
[ This Message was edited by: Joes924 on 2002-03-03 17:33 ] |
