Fuel Octane / Detonation
d12-Matt
Guest
PostPosted: Fri Feb 01, 2002 5:33 pm    Post subject: Reply with quote
What type of fuel do you guys use in your 924's? I heard that too low of octane can cause detonation in high compression engines. Last time I did a compression test all the cylinders showed around 140-150 PSI. Does that mean I need to use 91 octane fuel? Also, how would I be able to tell if detonation was occuring?
PostPosted: Sat Feb 02, 2002 3:54 am    Post subject: Reply with quote
Regular 87 octane should be fine, unless you've tweaked the engine at all... I run 89 octane in the racecar, with more advanced ignition timing.
Roger Hall
Guest
PostPosted: Sat Feb 02, 2002 10:21 am    Post subject: Reply with quote
maybe i like wasting money but the sticker says 91 octane so i use the 93 octane.
PostPosted: Sat Feb 02, 2002 10:49 pm    Post subject: Reply with quote
Yeah, seems like you do - those ratings are to old standards, RON rating as I recall... labels at the pump are an average of RON and MON (R+M/2), and therefore lower for a given blend.
Save your money.
Roger Hall
Guest
PostPosted: Tue Feb 05, 2002 2:19 pm    Post subject: Reply with quote
thanks i will
numbers
Guest
PostPosted: Wed Feb 06, 2002 7:51 am    Post subject: Reply with quote
85 octane is probably adequate for an NA, but for you Turbo owners, be sure you use the highest octane rated fuel available in you area.
