Takin' the plunge...
Kenodog
PostPosted: Wed Oct 29, 2003 11:19 am    Post subject: Takin' the plunge... Reply with quote
So I took the insurance off my car and built a shed around it for a little protection from the elements.Now for the hard part.I'm going to remove the engine and turbo to rebuild both and replace some hard to reach electrical components.When i'm done I hope to get another 23 years out of it (yeah right).So my query is;does anyone have any good tips or maybe things I should do to make the job easier?I'm only talking about removal and replacing the engine not the rebuild part.And is it easier to remove from the top or bottom.Any suggestions will be greatly appreciated.Thanks guys.
(if it makes any difference it's a '80 931)
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
OR_Sunset
PostPosted: Wed Oct 29, 2003 11:58 am    Post subject: Reply with quote
I don't know... I have pulled and placed my engine 3 times now. The first time, it took about 12 hours to get it out, and another 10 to go back in. The last time, I did the whole thing in a day, 6 hours to pull it, 8 to place and re-assemble. Getting the #$!!#$ thing in there is the harder part, as it has to be canted JUST SO in order to line up with the motor mounts.
If you pull the intakes and head off first (The easy way) make sure you get new gaskets and o-rings wherever you removed an old one. If you leave the head and intakes on (HARD way) be prepared to do emergency 1st aid when the engine starts eating your hand for lunch in the tight spots.
PostPosted: Wed Oct 29, 2003 12:31 pm    Post subject: Reply with quote
dont scare the poor boy, lol,
it isn't that bad I did it out the top and it wasn't bad w/ head and manifold attached,
3 928s,
Kenodog
PostPosted: Wed Oct 29, 2003 12:41 pm    Post subject: Reply with quote
so your sayin' a couple'o RedBulls and a fatty or two and i'm good to go..
1981 931, Sabine
2024 KLX300
2024 KLX140
Mikri184
PostPosted: Wed Oct 29, 2003 4:10 pm    Post subject: Sounds like my fun Reply with quote
In my experience out the top, isn't bad as long as you get everything out of the way. Remove the hood, you still need to drop the cross member,and taking the head off first, out the top is alot easier. Now if you want to leave it together drop the suspensions completely. Disconnect the electrics and joses. exhaust and the likes. ANd brong the whole thing out the bottom on a jack. I have done it both way both are about the same amount of work.
But the easiest is when the front end is off the car and you can take it straight out. Yeah this is the easiest.
Take Your time
Clean everything
You would of done well to pressure wash everything prior to sticking it into the shed. Makes dealing with dirty parts alittle nicer.
Have fun, Make sure you have a book or two. ANd if you can get a friend to give you a hand during the hard arts your doing well. I do al my engine pulls alone. I have gotten real good at it.
Most important Have Fun!
Life is to short to be looking for something?
PostPosted: Wed Oct 29, 2003 9:31 pm    Post subject: Reply with quote
I know take everthing off the block you can then take it out and when putting it back in keep it simple again its not to tough I did it by myself well my girlfriend helped a little by raisen and loweren the engine while I moved it around..Whatever you do keep the head off if you can.
CMXXXI
PostPosted: Thu Oct 30, 2003 5:29 am    Post subject: Reply with quote
I pulled the engine out of my 931 last month and it is still on a stand, waiting on a replacement head. With the exception of removing the hood, I've done everything alone.
Removing all the "required" engine bay components, dropping the front suspension and pulling back the transmission & torque tube took me about 4-6 hours. I had "issues" with the motor mounts, but once I overcame that, unhooking the last of the engine bay and hydraulic plumbing, and actually pulling the motor only took about another hour.
I suggest you pull the entire motor out the top, head, manifolds and turbo still attached. Here's why: To remove the head, you have to remove the exhaust manifold. To remove the exhaust manifold, you have to remove the turbo (or everything except the turbo-to-block mount). If you've ever removed/replaced the turbo with it in the car, you'll understand perfectly. Good luck getting to the manifold bolts with everything in-place.
Bottom line is that the turbo has to come just about completely off. It is just as easy to leave things as they are and remove the entire engine, then remove things where you have some working room.
'79 Eurospec 931
PostPosted: Thu Oct 30, 2003 6:27 am    Post subject: Reply with quote
cmxxxi is making good sence as usual ..I dont have a turbo
so never worked on one .See on the na its easier..if its best to leave it together it still shouldnt be to hard to remove..htough maybe you should recruit another person for the install . I still say for the removal take as much off as you can..When I spun a rod bearing a 2 ago I dropped the block out the bottom all that was left was the block ,crank, oil pump..pan was off
rods were out.. Installing is gonna be where you encounter the alien.
Eturbo924
PostPosted: Thu Oct 30, 2003 6:40 am    Post subject: Reply with quote
So on a non-turbo is it best to go out the bottom. I figured to put the car up on ramps and take out the cross memeber, disconnect the tie rods and lower the engine out the bottom.
I agree with no front end on it is easy. I took my 944 motor out that way. Cut the entire front section between the lights out. Of course that section was junk anyway.... but way fun and easy
I do not have an engine hoist so that is why I am thinking out the bottom for the 1980 NA engine.
Eric
1992 968
2003 C4S
Parts Parts Parts and More parts.
E-mail me for parts you need!
Drive Fast!
Kenodog
PostPosted: Thu Oct 30, 2003 9:16 am    Post subject: Reply with quote
So are you saying I have to remove the tranny and torque tube to remove the engine?This will be more work than I thought.
1981 931, Sabine
2024 KLX300
2024 KLX140
CMXXXI
PostPosted: Thu Oct 30, 2003 9:43 am    Post subject: Reply with quote
True, but really all you are doing is sliding the thing backwards about 10-12 inches. Support the transmission on a floor or transmission jack with wheels, put a block of wood under the fore-end of the tube, and pull/lever the whole thing to the rear after disconnecting the CV shafts, backup light switch, gear shift (at the shifter), and the mounts themselves. It actually sounds harder than it is.
You have to disconnect the torque tube at the bell housing, drop the transmission off it's mounts and slide the whole thing back as one assembly. This has to be done in order to disengage the actual drive shaft (inside the torque tube) from the clutch. Otherwise, you'd have to move the engine forward (and completely level) about a foot to get it off the drive shaft.
(Forgot to add in my previous post...even though Haynes and the factory manuals don't say to remove the radiator (only the fans), I think that you will thank yourself if you go ahead and remove the radiator. It'll give you some extra inches of working room, and besides, it's just as easy to pull the radiator as it is to pull the fans.)
'79 Eurospec 931
PostPosted: Thu Oct 30, 2003 9:55 am    Post subject: Reply with quote
no you dont, take out the rad and undo everything from the engine and undo the 4 bolts holding the torque tube to the bellhousing, then undo the motor mounts, and lower/wiggle engine around to get the motor mounts out and then slide engine forward and lift it right out
man I make that sound easy
3 928s,
PostPosted: Thu Oct 30, 2003 10:36 am    Post subject: Reply with quote
Yep,no need to slide back the tranny or tube, just remember to drop the steering rack, and the cross member or the oil pan will hang up.
CMXXXI
PostPosted: Fri Oct 31, 2003 4:26 am    Post subject: Reply with quote
Perhaps it is possible to remove the thing as they suggest, all I can say is good luck doing it. These photos will give you an indication of how far the engine has to be separated from the drive tube (tube all the way to the rear in the photos). You be the judge as to whether you think you can safely shoe-horn the whole thing in and out in the space provided. I suspect you'll be hard pressed to keep the assembly level while pulling the mass of the motor on and off the shaft.
Let us know how things turn out.
'79 Eurospec 931
PostPosted: Fri Oct 31, 2003 5:09 am    Post subject: Reply with quote
cmxxxi, I have pulled the engine out of a 931 w/o moving the torque tube back or unbolting the tranny, just removed ran and pulled forward worked fine
3 928s,
