ProudGecko
Posted: Thu Sep 18, 2003 1:35 pm Post subject: removing the transmission |
Today I started replacing the clutch in my '88 924S. I was not off to a good start because I had to drill out 4 of the 6 header to exhaust pipe bolts. After that everything seemed to go well as I lowered the exhaust and prepared the transmission for removal. I've now hit a snag as I'm trying to remove the transmission. I can't move it back far enough to get the torque tube coupler to dislodge from the splines on the transmission, I keep hitting the spare tire well. Any advice would be appreciated. If I don't figure something out soon I'm just gonna cut a hole in the tire well then patch it when I'm done. _________________ 1988 Porsche 924S
1986 Kawasaki Concurs ZG1000
1984 Mercedes 190D
1973 Honda CB500 |
Posted: Thu Sep 18, 2003 3:27 pm Post subject: |
undo the bolts on both ends of the coupler, tranny side and torque tube side
I do know it can be difficult, but is possible, then you can slide the coupler onto the tranny and get it out of the way _________________ 3 928s, |
ProudGecko
Posted: Fri Sep 19, 2003 3:48 am Post subject: |
Thanks for the tip, all I needed to do was slide the coupler into the trannie not the torque tube and it came right out. It also probably helped that I had a nights rest so my mind and body wasn't burned out anymore lol. _________________ 1988 Porsche 924S
1984 Mercedes 190D
1973 Honda CB500 |
Posted: Fri Sep 19, 2003 5:05 am Post subject: |
Hey I posted an answer on the other place you posted proud gecko glad to see you got it out without doin what you were thinken of _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
