Strange feeling when gearshift.........
Porscheaddiction
PostPosted: Fri Jul 25, 2003 3:27 pm    Post subject: Strange feeling when gearshift......... Reply with quote
HI all,
its a strange feeling when the gearshift breaks off in your HAND!
It happened at work..of course no tools..limped it home.
Drilled out the metal where the pin connects up to the tranny shift arm where it was broken off. Drilled through the shift leaver completely and put through a combination of 2 washer bolt and nut....lock tighted.
All is well now. At first I saw $$$ float by....
so if this ever happens to anyone else it can be fixed with out changing out the shift lever.
Chriis.
PostPosted: Fri Jul 25, 2003 4:54 pm    Post subject: Reply with quote
yah it can be but it is noisey as hell if you leave it like this, trust me, get a new one
3 928s,
Minus000
PostPosted: Fri Jul 25, 2003 5:12 pm    Post subject: Reply with quote
Happened to me, luckly just getting out of the driveway. A had a freind of a freind who is a professional welder do it properly (looked as if the previous owner had done it in the past) and its been fine. Perfectly aligned. Also, to deaden the wrattle a bit (which there was there at certain rpm) I wrapped a small peice of ducttape around the extending rod, then slowly worked the shiftlever on nice and tight. Works very well.
PostPosted: Fri Jul 25, 2003 5:33 pm    Post subject: Reply with quote
a better fix is a plastic sleeve fo a snailshell shifter in there
3 928s,
Porscheaddiction
PostPosted: Fri Jul 25, 2003 11:12 pm    Post subject: Reply with quote
Noisy? really?
I actually find its the opposite I find it much more quiet and shifting seems better too now. I am begining to think the piece that broke was on its way out for a long time.
Chris.
924Dann
PostPosted: Sat Jul 26, 2003 1:42 am    Post subject: Reply with quote
When I had my '82 I was playing around with my buddy in his GLI and went for a downshift when the shifter fell off in my hand!!! Needless to say I freaked out and didn't know what to do. I pulled up the shift boot and found the C clip came off the end. I connected to two pieces back together and limped to a hardware store to buy a new C-clip. After that it was fine. But imagine being 18 and have to think about buying a new tranny. That's the first thing that came to mind.
Former Porsche 924 owner.
I WANT ANOTHER ONE!!!
78porsche924
PostPosted: Sat Jul 26, 2003 5:19 am    Post subject: Reply with quote
My drove a pinto when she was a kid that was a stick shift. She was driving along and the entire lever came out in her hand. She did have the $200 to fix it so she superglued it back in. Worked great for a couple years and then she sold it. Personally, i wouldn't have the warm and fuzzies about driving when my shifter is superglued.
90 944 S2
78 924 NA <---now sold and killed by new owner
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
positivesale
PostPosted: Sat Jul 26, 2003 9:01 am    Post subject: Reply with quote
So it wore down to such a thin little cone shaped pin, that it snapped off and broke?
Is a common problem, but if you use a bolt, won't the threads be sharp and cause more wear? I'd line or wrap those threads up.
Sometimes if the C-clip on there is not on fully, it may be too loose. You can bend it tighter with pliers so that when you snap it on, it's a snugger fit.
Sleykin
PostPosted: Sat Jul 26, 2003 5:03 pm    Post subject: Reply with quote
I had a 63 Pontiac tempest with the trans axel and torque tube. Gearshift fell off and dropped out the bottom. I used 2 big hose clamps and a block of wood to put it back together. That was a slant 4 too ... I wonder if that is where Porsche got the idea
Glenn Neff
Medford, OR
87' 924S
Porscheaddiction
PostPosted: Fri Aug 01, 2003 2:42 am    Post subject: Reply with quote
No it didnt wear down...it just seems that the metal fatigued somehow and just let go.
On another note use my fix only as "tempory" with the vibration from driving the clip can fall off....also Lock whashers/nuts loosen anyway even with locktite..
Chris.
