awilson40 Guest
Posted: Thu Oct 25, 2001 11:19 am Post subject: |
After adding a free flowing exhaust, I get a pit of popping when decelling, downshifting and, sometimes, when briskly upshifting. Mixture seems fine and all 'lambda' circuits are functioning. Is this normal when changing exhaust?
Posted: Thu Oct 25, 2001 12:03 pm Post subject: |
Not uncommon... I've got quite a bit of popping, with my MSDS header, 2.5" pipe, and single bullet (through-flow glasspack-style) muffler.
jamez Guest
Posted: Thu Oct 25, 2001 1:24 pm Post subject: |
| mine does the same thing too... |
bacook Guest
Zuffen
Posted: Thu Oct 25, 2001 11:30 pm Post subject: |
Common problem it seems as I have it at times after a hard run. I wonder if the decel valve is loosing effectiveness.
awilson40 Guest
Posted: Fri Oct 26, 2001 2:52 am Post subject: |
Thanks guys.
BTW... I removed the Decell valve on mine. It was working properly, but I saw no difference with it on. The plastic port on the intake that the decell went to had broken off so I just plugged it and removed the decell valve. |
eturbo924 Guest
Posted: Fri Oct 26, 2001 9:32 pm Post subject: |
How is the car running otherwise? How is it under part throttle? Mine was acting similary until I retarded the timing just a bit. Seems I had it set to agressively. Not sure where it is at the moment. It is being painted at the moment. Anyway try a bit less advance and see what happens. Helped mine. I have bursh header and 2.5 inch exhaust. You can see my system on my site under my projects.
Eric |
awilson40 Guest
Posted: Sat Oct 27, 2001 6:01 am Post subject: |
Thanks, good idea. I might retard the timing a bit. I think I'm running a few degrees advance over spec. It runs great otherwise, no hesitation or flat spots. It has always idled a bit rougher than I would like but not too bad.
