dgz924s
Posted: Fri May 09, 2003 11:17 pm Post subject: Will 944S2 sway.... |
| bars fit on the 87 924S? 89 s2 tia D |
-nick
Posted: Sun May 11, 2003 4:28 am Post subject: |
yup, all swaybars from the late '82 924 and up will swap. all the way up through the 968. what are the S2 sizes? just make sure to get the bushings too.
-nick |
dgz924s
Posted: Sun May 11, 2003 9:03 pm Post subject: |
Thanks Nick! I wasn't certain on the S and S2 models. S2 is 26.8mm and 16mm rear. D  |
-nick
Posted: Mon May 12, 2003 3:36 am Post subject: |
-actually, before you committ make sure the front bar fits. i might have led you astray, i'm not positive the later bars fit with the early steel a-arms in the front. the rears will swap for sure.
good luck
-nick |
Porschephile
Joined: 04 Nov 2002 Posts: 825 Location: Denver, Colorado
Posted: Mon May 12, 2003 3:56 am Post subject: |
hey dzg, check out 968 M030 rear sways. 19mm, and adjustable. they are nice. _________________ werd B. |
