Capt EZ
Joined: 20 Feb 2003 Posts: 441 Location: Slidell, Louisiana (east on I-10 from New Orleans) 70458
Posted: Sat Apr 05, 2003 8:23 pm Post subject: Brake Pads? |
I am getting ready to start shopping parts for a brake job and want to know what are the best pads for a daily driver as far as what ones gove the best compromise of performance vs. wear, dust, squeel, cold performance ect. I am not looking to throw myself through the windscreen or to make it uncomfortable for a "passenger" but, I do want a pad thet grabs when I am alone.....kinda that stage between track and street / daily?
I plan on doing the front with new rotors, also. Are drill or slotted rotors reccommended? What are ya'll's opinion on gas slotted rotors? What bearings have held up? Has anyone painted thier calibers during a rebuild and what is the best method of doing so?
Being that this is a daily driver, I like to have all parts on hand for the job on the weekends so that it can be comploeted for Monday morning...any opinions?
Also, rears are next, should I try the rear bearings? I heard that they are labor / tool intensive> _________________ Dream as if you'll live forever.
live as if you'll die today. - James Dean
Fly Fast
Live Slow
Margaritaville Airways
1987 924S |
Posted: Sun Apr 06, 2003 12:34 am Post subject: |
| IMO, stick with the stock rotors, the slotted and drilled ones are hype and don't last as long. |
Capt EZ
Posted: Sun Apr 06, 2003 1:59 am Post subject: |
Sounds good to me, I never have a problem with saving money....any ideas on pads? _________________ Dream as if you'll live forever.
Fly Fast
Live Slow
1987 924S |
Joined: 29 Jul 2001 Posts: 9081 Location: Royal Oak, MI, USA
Posted: Tue Apr 08, 2003 12:46 am Post subject: |
I'm very fond of the PBR (nee Axxis) Metal Master pads for street use, though they can be noisy if used w/out disc brake goo. They can be a little weak when cold, but one stop will fix that. Paragon sells them, I think they're around $50/axle.
No need, IMO, for slotted rotors. _________________ Vaughan Scott
Porschephile
Joined: 04 Nov 2002 Posts: 825 Location: Denver, Colorado
Posted: Tue Apr 08, 2003 1:20 am Post subject: |
I went for stock rotors and Ferodo pads. work REALLY well for me. _________________ werd B. |
CMXXXI
Posted: Wed Apr 09, 2003 7:21 am Post subject: |
Don't have any pad recommendations, but I'd suggest blasting and powdercoating your calipers. Weren't you (recently) playing with the idea of getting your wheels re-done too? Take everything at once and you probably will get a lower rate than two separate jobs. Color guaranteed to match too if thats what you want.
During this "restoration" project I'm in the midst of, I cleaned all my calipers up real good, rebuilt (a piece of cake) and then painted them. But, when I bled them the first time, drips of the brake fluid onto the new paint discolored them, and plain ate it away in one spot.
Last week I bought two used front calipers, hubs AND rotors off e-Bay for a whopping total of $51 delivered. I'm going to have the calipers blasted and powdercoated, then have the discs turned and I'll be all set (once I get the car running). _________________ '79 Eurospec 931 |
Capt EZ
Posted: Thu Apr 10, 2003 5:42 am Post subject: |
Thsoe were the same concers that I had about brake fluid. However i saw a caliber paint in one of the catelogs that I have to look into to see if it will inhibit the corrosion. I have been considering the powder coating both for the wheels and other parts and have gotten some feed back from several shops that they don't fool with wheels.... so, we'll see. Thanks for the feedback. _________________ Dream as if you'll live forever.
Fly Fast
Live Slow
1987 924S |
CMXXXI
Posted: Thu Apr 10, 2003 6:43 am Post subject: |
Refurbishing and powdercoating the new/used calipers isn't going to happen this month or next, but I'll post back to let you know how they turn out. My limited experience & exposure with the process suggests to me that the coating will be impervious to the fluid. I'd be interested to know how the "caliper paint" holds up over time. Certainly the manufacturers and aftermarket folks use something that holds up pretty well. But when it comes down to it, I think that the preparation of the part will make all the difference. _________________ '79 Eurospec 931 |
Capt EZ
Posted: Thu Apr 10, 2003 6:59 am Post subject: |
I agree with the prep work. I think I may try to find a set of calibers out there to have ready to go for the job.
Also, for the wheels, I think I may go to the 16x7 and 16x8 on the next set of tires so I am starting to look for a set of phone dials. anyway, I think if i have the wheels powdercoated, I am going to have the inside done in black and the exterior done in the closest to original as I can. I think the black would give the rim a nice set off and it would definitely be easier to keep clean - looking between details. As for the calibers, I like the red, but IMO I don't want to look like a wannabe Brembo, but they do stand out and I haven't ruled that out. I think matching them to the rim or black would look good also. I saw somewhere on the board that someone made "Porsche" stencils and applied the lettering like the 944 has to the calibers. It looked great. So, I have a few ideas that i am playing with now. Just undecided. _________________ Dream as if you'll live forever.
Fly Fast
Live Slow
1987 924S |
