Wiring Schematic for electric windows
Goto page Previous  1, 2
kondzi
PostPosted: Mon Jun 06, 2022 9:14 am    Post subject: Reply with quote
Konrad
'89 951 US
'81 931 RoW (TBD)
Gatornapper
PostPosted: Mon Jun 06, 2022 11:29 am    Post subject: Reply with quote
SUPER!
kondzi wrote:
I found my notes. Will post pics later as I cannot do it from Phone.
'87 944 S, looks & runs like new - sold my sweet 931; '76 914 2.0 mostly restored; 2011 Porsche Cayman S in Meteor Grey, 3.4L, Softronics ECU tune 355+hp , PDK w/Sport Chrono. Got this thing for Porsche's.......
Beartooth
PostPosted: Wed Jun 08, 2022 4:15 am    Post subject: Reply with quote
This thread should come in helpful soon, assuming I don't hit any sudden roadblocks getting my car going. The driver's side window is down, has been down since I got it, the door card is out, and it looks like somebody was fiddling with the switches and wiring. I moved it in the garage as soon as I got it, so getting the window up hasn't been a priority, but will be if/when I get it to where it's driveable. Given some of the questionable "repairs" I've found on the car, I may find myself having to back-track some things the PO did to get the windows working again. Nice to have some good information to work from!
1980 931 diamond in the rough
Gatornapper
PostPosted: Wed Jun 08, 2022 11:14 am    Post subject: Reply with quote
I'm hyper-busy right now but when I get some time I'll get the door panel down and chase down the wiring details and post them here.
GN
Gatornapper
PostPosted: Tue Aug 02, 2022 4:06 am    Post subject: Reply with quote
Only 3 wires go to the switch on either door: Brn ground, red/white - hot for up; red/black - hot for down.
Connector in lower kick panel in front of door on right and left.
Only 2 blue wires go to window motor - from the switch. There are no limit switches on the motors to cut motors off when windows reach their limit.
No idea WHY there are separate 12v + wires to the window switches when one would do.
My red/white wire had bad connection in panel connector. I used 12v+ from the black wire to power the window up and it worked fine - before I found the connector and fixed the problem.
Rebuilt right switch - down works fine, but not up. On driver door that used to work fine until recently now the up works for right window but not down.
Jaffar
PostPosted: Mon Aug 08, 2022 7:25 pm    Post subject: Reply with quote
I am not sure whether you have seen this video, but this worked for me.
https://www.youtube.com/watch?v=jbwk991LEfM
This guy has a few really useful videos on early 944s which also relate to 924s.
Porsche 944/924, Lotus Elan.
Beartooth
PostPosted: Wed Aug 10, 2022 4:14 am    Post subject: Reply with quote
I just cleaned up all my switches and put them back in. I'm actually not sure there was any issue with the switches: I kind of assumed there was because the driver's window was down and the door card has been off since I got it. The good news is, they all seem to work great; the bad news is that the driver's window won't move. You can hear the motor working, along with kind of a heavy clicking sound, so obviously something in the drive and/or regulator mechanism is broken.
Everything on the switches was correctly oriented when I took them apart. The contacts on both driver's side switches were significantly pitted though. I cleaned them up with Simple Green, water, and an old toothbrush. There was some mess from the grease in them: I'm not sure if somebody had taken them apart and added grease, or if it was just the original grease breaking down over time. Either way, that doesn't help electric contacts. I cleaned up the metal rocker contacts with a polishing stone on my Dremel, which did a nice job without removing too much material. I had to use a pencil stone to reach the top and bottom contacts in the socket part of the switch. I cleaned them again with automotive electrical parts cleaner, then used some Deoxit products (they make high grade cleaners, conditioners, and greases for stereo components) just to make sure any oxidation was gone, and finished it off with a contact conditioner. I assembled them with just a drop of grease where the BBs sit in the rockers; definitely a place to be minimal. A lot of grease will just make a mess and probably cause the switch to fail eventually.
For someone troubleshooting and just trying to get a switch working again, you could probably get there by wiping off the old grease, scrubbing with a brush and electrical cleaner, then giving it a final flush and blow out. I'd at least scrape the contacts with a screwdriver, and I'm not sure how long a quick clean is going to hold up. I suspect at some point the pitting on the contacts causes them to fail quickly: I've always been able to get switches to work well if I can file the contacts down flat. At some point, it sounds like you have to bend the ends of the rockers down slightly to compensate for the thinner contacts, and at that point, new switches are probably a better answer. I can't see any reason why you couldn't get any switch to work unless one of the pieces breaks, but at $30 or so a pop, it may not take much fiddling before you're burning more time than it's worth.
Anyway, lots of good info in this thread. It's very counter-intuitive to think that the switch on the right side could be fine but not function. Also, while I don't think most of us would just assume the rockers could go just any way, I definitely wouldn't have known if I was looking at one that was assembled wrong. One could just buy three new switches and be on their merry way (nothing wrong with that), but I for one can't stand the idea of spending money to fix something when fifteen minutes and a little know-how might be all it needs!
PopUpProject
PostPosted: Fri Sep 05, 2025 9:46 pm    Post subject: Reply with quote
Following this post and looking for any updates if there has been..... I am also going to be fighting my windows to work again as the PO decided I'm not going to fix these, I'll just slap duck tape over them so no one tries to use them.
Can I take the switch out without disassembling the entire door card?
Just trying my best to figure this out without total failure
Poppy the '82 924 Resurrection in Progress
PostPosted: Fri Sep 05, 2025 11:40 pm    Post subject: Reply with quote
Window switches are generally easy fixes on 924s.
You'll notice the switch is rather tall....there is a large two - pronged clip on either side of the main body of the switch. You require some body/trim PLASTIC removal tools ideally. Cheap as chips off the old interweb, or from your local auto store.
To remove the switch, apply pressure simultaneously to the upper and lower area of one side (pushing in) and lever that side out. Now the whole switch should just pop out. If you are clumsy and drop the clip into the door, you will have to remove the doorcard to retrieve it.
Carefully separate the wiring from the back of the switch (with plastic tools - not your favourite screwdriver) as the plastic on these 40yo parts is brittle.
Take the switch to a safe place and gently pry apart the rear section. You should find a metallic rocker lever, two springs and two ball bearings......and 40yrs of crud. Clean with WD40 or similar, dry off and reassemble with dielectric grease. Test before refitting completely.
Very little ever goes wrong with the mechanism, though if the metallic strip is seriously worn, some solder can build up the surfaces.
If this doesn't reinstate your window operation then you will have to dive deeper into the door and check motor wiring/motor/window mechanism.
PopUpProject
PostPosted: Fri Sep 05, 2025 11:52 pm    Post subject: Reply with quote
Awesome, thanks Peter!
chuck21401
PostPosted: Sat Sep 20, 2025 4:41 am    Post subject: Reply with quote
The passenger side window on my car has been problematic since I bought the car. The passenger side switch didn't do anything when pushed. From the driver's side, the passenger window would go up and down....but not consistently.
I put off dealing with it thinking that I'd need to pull the door panels and replace a window regulator or something. And I've done that before....once in a 911SC and once in a W124 Mercedes. I still have the scars from cutting up my hands from those two projects.
Anyway, I came across a thread on Reddit talking about 944 window switches...and that pointed to this video (also mentioned earlier in this thread)
Interesting. I pulled the driver's side switch panel and swapped the wires...and the passenger side window worked fine to my amazement.
I tried cleaning the problematic switch with contact cleaner...that helped but but didn't work every time.
So I bought a new switch from 944online through Ebay (https://www.ebay.com/itm/222281884855), installed it and both windows work fine now.
Page 2 of 2
