Nzl924
Posted: Sun Aug 10, 2025 4:49 pm Post subject: Headlights - Won't go down |
Hi All,
I've looked around the forum and couldn't find anything exactly as my issue. My headlights are going up but won't go down.
I have checked Clarks Garage and tested the power going to the 4-pin connector. All looks good except the green wire, it is reading ~11V while the other (blue?) reads ~12.6V when the lights are off. From Clarks Garage they should both read 12V when the lights are off.
So, if I short the green and blue together, the lights go down!
Is this likely to be an issue with the switch, poor connection somewhere? Does anyone know how to test the switch.
Thanks
Stu |
Nzl924
Posted: Sun Aug 10, 2025 5:24 pm Post subject: |
Tested resistance between pin 57k (which I think goes to the green wire on the headlight motor) and X when the switch is in the off position and it is reading ~0 Ohms, so I guess the switch is ok? _________________ 1981 Porsche 924 NA
(Last on the road 2011) |
Posted: Sun Aug 10, 2025 10:29 pm Post subject: |
Give them a tap with the palm, perhaps there is a mechanical issue that the motor cant overcome. _________________ Supercharger and EFI kits
https://www.the924.com |
chuck21401
Joined: 20 Feb 2005 Posts: 606 Location: Annapolis, MD
Posted: Mon Aug 11, 2025 3:38 am Post subject: |
Check the plastic cover that surrounds the headlights. Sometimes that can come loose and prevent the lights from moving freely. And in that case the motor can burn out or worse. Even after you turn off the ignition, the motor could still be trying to retract the lights. _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
Nzl924
Posted: Mon Aug 11, 2025 7:00 am Post subject: |
Thanks for the replies, I don't think it is a mechanical issue as if I supply 12V to the green pin the lights go down as you would expect. _________________ 1981 Porsche 924 NA
