Rugbreyð
Posted: Fri Jun 20, 2025 12:45 am Post subject: WUR Not Dropping to 3.6 Bar – Wiring Issue Suspected |
Hey everyone,
I'm having issues with my Porsche 924’s warm‑up regulator (WUR). The fuel system pressure climbs to 5 bar but never drops to the expected 3.6 bar. I’ve already:
Rebuilt it using a repair kit
Checked the heating resistor—measures ~20 Ω, which seems correct
Despite all that, it won’t settle down. I suspect the wiring is messed up—maybe from work done by the previous owner. Any thoughts on where to focus my troubleshooting? _________________ i have no idea what i am doing, but i have a dreeaammm, and that is to see my shitty 924 work agian after 20 years of not working |
Raize
Posted: Fri Jun 20, 2025 3:51 am Post subject: |
Wiring wouldn’t cause that.
Basically the flow through your WUR is extremely restricted
Something is assembled wrong, maybe heater strip upside down is a common mistake. |
Rugbreyð
Posted: Fri Jun 20, 2025 4:28 am Post subject: |
i don’t think I did anything wrong during the assembly. I’ll double-check it, but I followed all the steps shown in this video:
https://www.youtube.com/watch?v=zW5qV208tCA
I didn’t use any fluid sealant between the metal disc, unlike what I did in the fuel distributor. Could that cause the malfunction? |
Raize
Posted: Fri Jun 20, 2025 5:12 am Post subject: |
It shouldn’t need any sealant.
Apart from a mechanical issue with your rebuild:
1. Not using the pressure tester correctly (valve is closed, or stem has snapped and you didn’t notice)
2. Pressure tester connected in wrong place (Should be connected to the fitting on top of the fuel dist)
3. WUR plumbed incorrectly (CSV swapped with WUR return is the only way this could happen I think)
4. Extreme blockage of the WUR in/out filter screens.
5. Previous owner has been hammering at the WUR fuel cell to try and lean it out and screwed up the depth setting. Check for witness marks.
6. Collapsed fuel hose somewhere. |
Rugbreyð
Posted: Fri Jun 20, 2025 5:34 am Post subject: |
I have connected the tester correctly, and no fuel hose is collapsed-
It could be extreme blockage of the WUR in/out filter screens, how could i check and also clean these filter screens.
And what do you mean by WUR plumbed incorrectly, and in number 5, what screw are you talking about, i dont think i have any screw. |
Raize
Posted: Fri Jun 20, 2025 5:53 am Post subject: |
The filter screens are just under the banjo bolts, it would be quite obvious if they’re full of debris, you could maybe dig it out with a toothpick or blow it out with compressed air.
You might have the fuel line for the CSV connected to the WUR return line which would mean that both sides of the WUR would just see system pressure. Easy to check - the return line of the WUR should trace back to the overall return line on the fuel distributor.
And by screwed up I just mean broken, no screws involved. The adjustment for the fuel cell literally is just tapping it in or out with a hammer. |
Riggard
Joined: 16 Feb 2021 Posts: 90 Location: Heemskerk, Netherlands
Posted: Fri Jun 20, 2025 5:58 am Post subject: |
try blowing through the fuel return line.
Also, what you could try to do to rule out incorrect assembly/setup of the wur, is open the underside and remove the spring + pin. If control pressure drops after that, you need to fix the WUR. |
Posted: Fri Jun 20, 2025 3:23 pm Post subject: |
I always struggled with WUR control pressures being either completely out of range or at least out of range for either cold or hot conditions.
Calibration is a very delicate process, you normally need a test bench with fuel flow attached to it, ability to warm up and cool the WUR, 12V and of course a pressure gauge.
And then you should be able to slowly adjust the WUR to fit the needs as best as it can.
If you dont want to do that, you can always order an EFI kit from me.  _________________ Supercharger and EFI kits
https://www.the924.com |
Raize
Posted: Sat Jun 21, 2025 12:28 am Post subject: |
| morghen wrote: |
It’s not even guaranteed that the car will run well if you get exactly the book values either. Back when I had NA kjet it needed considerably lower hot and higher cold control pressures than the book suggests, to have what I considered appropriate AFR values. Especially cold it would be borderline rich misfiring for the first minute.
Too many variables when the engines and parts are this age, it’s good to have something adaptable like the EFI or at least a wide band sensor to see what you’re doing. |
Rugbreyð
Posted: Sat Jun 21, 2025 4:05 am Post subject: |
I’ve now taken the WUR apart again, and everything looks fine. The filters don’t appear to be clogged. I also tried starting the car with the bottom section and spring removed from the warm-up regulator, but nothing happened. it stil is at 5 bar fuel pressure.
However, I didn’t have power connected to the WUR during that test, does it need power for anything to happen in that scenario?
Also, when you guys mention “calibrating” the WUR, what exactly do you mean by that? |
Rugbreyð
Posted: Sat Jun 21, 2025 4:12 am Post subject: |
And here are some photos i took of my warm upp regulator
Images inside the WUR
Images of the filters
gml
Joined: 04 Mar 2021 Posts: 133 Location: Ontario Canada
Posted: Sat Jun 21, 2025 5:11 am Post subject: |
I'm dealing with my WUR right now. I had system pressure = control pressure (4.6 bar) even with the bottom half removed (no spring), and even though I rebuilt my WUR. My inlet filter screen looked as clean as yours, but I still blasted throttle body cleaner from the inside out. After a few rounds of that I'm reading control pressure is 0.6 bar without the WUR bottom half (no spring)
The inlet screen consists of 5 mesh layers that get increasingly more fine. I suspect the most fine layers are clogged up with old fuel varnish that needs to be patiently dissolved. _________________ George
1982 924 NA 5-speed |
Posted: Sat Jun 21, 2025 10:41 pm Post subject: |
Thanks for the pics, that helps the discussion a lot too.'
The recalibration or adjustment is done by moving the base of the bimetallic strip - where it's secured on a stud with a nut. That sits on a plug that's inserted in the upper body of the WUR, and by moving the plug in and out the pressure can be adjusted.
But as this is done by tapping or pressing - it's a real pain to do outside of a test bench... so linked in the other thread from gml there's the instructions on how to fit it with a screw to make it a bit easier to adjust. _________________ Vaughan Scott
Riggard
Posted: Sun Jun 22, 2025 6:23 am Post subject: |
The fact that removing the strip does not change the pressure, means that either the WUR, or something else in that path is clogged.
Fuel goes from a very small hole in the distributor to the WUR and then is fed back to the tank via the return line.
When I had this symptom (System pressure = control pressure) the return line was clogged. I blew it through and that helped. But it could also be the WUR itself as mentioned above.
With calibrating the WUR, we mean setting both the cold and warm pressure. The warm pressure has to be set first, by pushing in or out the black fuel cell. The cold pressure can be adjusted by adjusting the pin, which is often done by tapping a bolt in it with a nut. I would say this has to be done whenever the WUR is opened/rebuilt. Though I've rarely seen people do it properly. |
Posted: Mon Jun 23, 2025 5:47 pm Post subject: |
| Riggard wrote: | | With calibrating the WUR, we mean setting both the cold and warm pressure. The warm pressure has to be set first, by pushing in or out the black fuel cell... |
Ah, this is interesting - I've not heard this called out specifically, but it makes sense I think... you mean to move the black piece that the fuel connections attach to? I can see this working just the same as the other adjustment... _________________ Vaughan Scott
