Goldwolf
Posted: Fri Feb 28, 2025 6:06 am Post subject: 1981 924 Weissach #179 for sale $8500 |
I am only listing the car here for now. I want it to go to someone that cares about these cars and will take on caring for this one. I can answer any questions, I know everything about this car. I have receipts for all the work and can tell you the 2 shops that have worked on the car. It starts every single time. It is driven once or twice a week. Original tweed upholstery, a little dirty. Car pulls well, runs great. No rust. Glass in great shape. All electricals work, mirrors, signals, lights etc... I am the second owner. Car has been registered and insured in Georgia since 2016. I do not have a Georgia title, bought it from Pennsylvania and could not get the original. Georgia does not issue one for older cars. Copy of the background check and original bill of sale will be included. Car is located right outside Athens, GA. I easily have 12k in the car, not that it matters, but I tried to do it right. Send me a pm if interested.
You can see my thread here https://www.924board.org/viewtopic.php?t=43283&postdays=0&postorder=asc&start=0.
Engine:
rebuild complete in 2019
all cylinders sleeved
1 valve replaced
2 lifters
exhaust manifold replaced
water pump replaced
Vacuum lines replaced with cloth covered hose
Fuel System
all injectors replaced with Bosch
cold start injector rebuilt
aux air valve rebuilt
wur rebuilt by cis flowtech
fuel distributor rebuilt by cis flowtech
fuel sender replaced
fuel pump was replaced before I bought it, no issues
transmission
clutch replaced
body
windshield replaced
coco floor mats
left rear taillight lens replaced with OE used unit
No leaks under battery tray
Sunroof seal replaced, I have the inner seal to replace, only944 parts
I have B pillar replacements to install
Replacement sunroof bag
Have rear hatch seal to install from only944
Visor clips replaced with black aluminum
Sunroof latches replaced
Coverlay dash cap, not installed yet
Driver's seat rail cleaned/lubed, and sprayed, mount points sprayed
Carpet "painted" brown, looks ok.
i have new door handle seals and badge seals in the package
New 924 threshold stickers from Werk924, not installed
New rear 924 sticker, not installed
electrical
wiper motor rebuilt
fuses and relays checked and replaced
original alternator rebuilt
distributor disc replaced and rewired
alternator ground strap replaced
oil pressure sender replaced
A/C compressor rebuilt
A/C mounting bushings replaced
Blower motor reconditioned
brakes
front rotors replaced
front wheel bearings replaced
updated calipers from VW Passat installed, no modification
needed, originals retained
suspension
front shocks replaced
front bushings replaced
front control arms replaced with better used units, originals retained
Things that the car needs:
02 Sensor wire/plug repaired
Odometer gear replaced, speedo cable reattached at the wheel
Wipers work on slow speed, high speed causes the engine to cut off,
that's a crazy one, gotta be a ground?
Things the car wants:
Most of the side moldings have come off from age.
Fuel accumulator, the one thing I have not replaced it seems. But no issues.
Carpet would be nice, it's passable and normal people wouldn't notice.
Wheels refinished.
Paint, at some point it looks like a scuff and shoot was attempted or
the paint underneath the clear is "crazing" not sure. It's hard to see in
pics and even in certain lights, but it looks like sanding marks. The
front end was repainted and probably a C- job. Chips on the sunroof panel, and roof. Again, a lot of people
don't notice and you can drive it and not be embarrassed.
I can get some better pics as well.
Photos
https://photos.app.goo.gl/wY86HdBcr17W9mie9 _________________ 1981 Weissach Edition #179 |
Goldwolf
Posted: Tue Mar 11, 2025 3:37 am Post subject: |
Forgot how to use imgur last week.
more pics in the linked google gallery _________________ 1981 Weissach Edition #179 |
Glemon
Posted: Wed Mar 12, 2025 3:22 pm Post subject: |
Beautiful car, my garage is filled up, but that is a good looking 924 _________________ 88 924S
68 TR250
02 IS300 |
