GTS Center Console
Goto page Previous  1, 2, 3, 4
PostPosted: Tue Feb 04, 2025 1:26 pm    Post subject: Reply with quote
Work in progress on the Innovate Gauge on right side. You can also see I took out the lower section cutout fillet so it looks more period correct to the dashboard
Also thinking the gauge needs to go in farther still. That bezel is big!
Edit: You can see the VDO to Innovate difference from Left to Right. Hole size for rear of gauges is the same!
PostPosted: Tue Feb 04, 2025 7:11 pm    Post subject: Reply with quote
Brilliant !
PostPosted: Tue Feb 11, 2025 2:03 am    Post subject: Reply with quote
Thank you! I adjusted this since the last post to set the Innovate gauge deeper and adding oring spacer(s) that could go into the bores so you could adjust the gauges in or out to match face depth between different gauge brands
Then I had a cold this past week which had me sitting in front of my computer a lot this weekend playing around with a Single Pod panel idea with the thought that maybe someone would just want a clock only option.
Six versions so far but I am learning that the simple versions seem to look best. Also to your request Morghen, I might just make the symmetrical dual version from this single pod idea. At least start here
Page 4 of 4
