Posted: Sun Aug 18, 2024 1:52 am Post subject: |
Well this wasnt a very well uppdated thread Last year got lost because the engine was blue smoking alot when it was finally started up, after tearing down alot of stuff, including removing a piston (shitty job) removing the head (also a shite job) and the conclusion was that there was a score in one of the valve guide bores, from either when they were pulled out or in. The company who did the engine work fixed it, but it sucks since i lost a driving season pretty much.
Anyway, its on the road now, and I had a few test drives, to continue to get some driving time on the engine. Ive also had a few fun test drives on twisty roads to try the new GAZ gold suspension.
Current status
Engine:
I had some issue with a weird rev hang when it got warm, disconnected the decel valve and it disappeared , very strange.
It pulls really well, and it will not be very long run in process, i mean 0,7 bar is part load now that i can run 1 bar of boost:) The last oil i took out was crystal clear, so i think not much more will happen from now on.
The fuelling which have always been rock solid since 2009 or whatever year i started driving it properly have now jumped a whole step in AFR, which means its running pretty rich. With the boost line to the wur unhooked (ive had that before aswell) it runs 11.-11.4 at full boost 0,7 bar and 13ish at cruise, so i will have to sort the cruise fuelling at some stage.
I will keep it at the standard 0,7 bar for a while, its still very strong, and i want to have everything under control before I let it back on higher boost
Suspension:
Really like the new dampers, i was afraid they would be to much for the road, but actually they are better at handling bumps then my old less racey dampers. Its still on 350lbs springs, but I feel that the 425 that i also ordered could work as good, ill test that later, its a bit fiddly since i need to put the springs on the rear dampers to balance it, but i have them aswell. The only strange thing is that the rear right damper sounds weird, like a bicycle pump, trying to get some input from GAZ.
New brakes:
The new brake setup is working really well, nice pedal feel and good power modulation. The Ferrodo DS3.12 are pretty brutal when they get hot though, a bit to much bite for road tyres, lets hope it fits my wider track tyres well . However i might need to get some better rear pads to balance it up, im not sure what to get since i have to look at a mixed setups with different manufacturers.
So after fixing a few small issue like a loose boost pipe etc, hopefully i can continue to accumulate more driving and test things out a bit more. Not sure that I will have time to try any track or so this season, otherwise I will do that in the spring instead, im not stressing it. Im just glad that i can have fun on the twisty roads, which i have plenty of around here.
 _________________ 1980 924 Turbo
Posted: Sun Aug 18, 2024 1:57 am Post subject: |
Oh, and i get so many questions on my intercooler setup from guys on FB groups etc, so i will probably do a write up here in the near future  _________________ 1980 924 Turbo
Posted: Sun Aug 18, 2024 5:07 am Post subject: |
Really happy that you’re finally driving it and enjoying it. _________________ Supercharger and EFI kits
https://www.the924.com |
Joined: 14 Dec 2004 Posts: 1797 Location: Chicago-ish
Posted: Mon Aug 19, 2024 12:56 am Post subject: |
| morghen wrote: | | Really happy that you’re finally driving it and enjoying it. |
I second that feeling! I was wondering what was going on since I saw a lot more of the race car than this one on Instagram.
At a car show last night there was a GTO (pretty sure thats what it was) with so much space between the engine and radiator you could easily just stand in that space. I thought why do I choose the 924 to work on instead
Again, nice to see your car on the road again _________________ 1980 931 since 1989
Raize
Posted: Mon Aug 19, 2024 3:35 am Post subject: |
| The intercooler is very nice and stealthy. Really nice looking car in general. |
Posted: Mon Aug 19, 2024 4:49 pm Post subject: |
| Mike9311 wrote: | | morghen wrote: | | Really happy that you’re finally driving it and enjoying it. |
Again, nice to see your car on the road again |
Hehe, when i see guys swapping head gaskets in the pits i also wonder why I do this, when its a friggin winter project and hundreds of $ (and swear words) for me . But it could be worse, its no 300ZX. _________________ 1980 924 Turbo
Posted: Wed Dec 04, 2024 12:55 am Post subject: |
Cedric, can you give more detail on the brakes? Pretty sure I know they are Boxster / Cayman 2009-2012 or so calipers right?
I have been playing around with a project idea using 2017-2020 (+?) Cayman / Boxster Base calipers to see if they might drop a tiny bit of weight compared to the 968 Brembo Blacks on the car now. I just can't find any trustworthy info on the Caliper differences no matter how I look. 68 rotors should be 28mm which should match. While yours I believe were for slightly thinner rotors. I know I am wasting my time but you know me. Its a mental exercise when I am doing something else
Your setup looks awesome _________________ 1980 931 since 1989
Posted: Wed Dec 04, 2024 6:43 am Post subject: |
| Mike9311 wrote: | Cedric, can you give more detail on the brakes? Pretty sure I know they are Boxster / Cayman 2009-2012 or so calipers right?
Your setup looks awesome |
Boxster 986 non S calipers,.the ones with the same piston area as the std calipers. Its difficult to find details for sure, even harder nowadays when internet search results are a pile of poo. My Carrera discs are 24mm, i dont remember what the Boxster discs are, a few mm thicker than that. _________________ 1980 924 Turbo
Posted: Thu Dec 05, 2024 12:10 am Post subject: |
| Cedric wrote: | | Mike9311 wrote: | Cedric, can you give more detail on the brakes? Pretty sure I know they are Boxster / Cayman 2009-2012 or so calipers right?
Boxster 986 non S calipers,.the ones with the same piston area as the std calipers. Its difficult to find details for sure, even harder nowadays when internet search results are a pile of poo. My Carrera discs are 24mm, i dont remember what the Boxster discs are, a few mm thicker than that. |
"internet search results are a pile of poo" Totally true.
Thank you for all that info. From you I know its good _________________ 1980 931 since 1989
Posted: Thu Dec 05, 2024 5:12 am Post subject: |
Many have probably seen it on my IG or similar, but heres the pics to keep continuity in the thread.
As a fun little side project I made a bracket to stiffen up the master cylinder, it moves a little bit under really hard use, and why not try 3D printed aluminum at the same time to get a feeling on how it works for consumer use. It also fits well with the improved braking feel of the Boxster calipers.
So I did a quick and dirty scan, not great but without any prep, but good enough to design a few plastic printed iterations and the order the alu printed one. Sucessful so far with the garage testing, it greatly reduce the movement with really hard brake application, but since its winter i only tried it in the garage. The small flex that is still there is in the strut mount bracket, so quite diffcult to do anything about, the strut bar mounts arent designed for the twisting force.
Im really happy with the parts so far, so i will probably do more metal printing in the future, would be fun to do stainless aswell !
Made it in fusion, the scan is reduced to improve speed as Fusion dont like big meshes.
Posted: Thu Dec 05, 2024 9:25 am Post subject: |
That is cool! I missed your IG _________________ 1980 931 since 1989
kondzi
Posted: Tue Mar 18, 2025 11:06 pm Post subject: |
So cool! Can you sell me one?  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Wed Mar 19, 2025 2:54 am Post subject: |
| kondzi wrote: | So cool! Can you sell me one?  |
Its very specific though, for this brand of strut bar, otherwise i would have probably ordered at least two  _________________ 1980 924 Turbo
kondzi
Posted: Wed Mar 19, 2025 6:58 am Post subject: |
| Cedric wrote: | | kondzi wrote: | So cool! Can you sell me one?  |
Its very specific though, for this brand of strut bar, otherwise i would have probably ordered at least two  |
My strut bar is not yet there. Still need to finish the intake and then I will fabricate strut bar. So for me it still makes sense. Surely I can "borrow" the idea and make similar thing on my own, but if it's already there... Credits for the idea/design
Anyway, I still have time, but need to check my M/C if it will work, as I've replaced the stock one with one from Mercedes G'ish (25.4mm) and changed form the X-setup to Front/Rear. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Thu Aug 14, 2025 3:13 am Post subject: |
Ive been bad at updating, here some more for continuity sake.
Some updates from the MOT test and fixes before, which into a possibility to shed weight. The car was approved, so next MOT in 2 years.
Also had a first test on track(albeit small) in a long time, after some issues with the wiring I had a great time on track, didnt hold back, otherwise theres no point in testing Magnus (known for the wild 924 ratrod in here) had his 911 Targa and we had a really fun session on track.
In general I was very happy with the new GAZ dampers, took the very bumpy track really well, i just need to do some anti roll bar adjustments to perfect the balance. The brakes felt super strong with my new setup together with the wider wheels, very impressive. The updated boost pipes including the 3d printed turbo intake worked well and the engine is really strong and flexible even at this low boost level (which i will keep it at for a while). Hopefully i can find time for a bigger track test later on to strech its legs!
Heres some video of it:
https://youtu.be/U54RDgmheSk
