1977 924 Engine Swap
chasehubbard
PostPosted: Mon Aug 26, 2024 3:46 am    Post subject: 1977 924 Engine Swap Reply with quote
I have been working on a 1977 924 that I got cheap with a blown engine. This is my first 924 (and my first engine swap) - so I am looking to make this as painless as possible.
I have since learned that I have a true '77 engine currently (not a 77 1/2). When shopping around for an engine from junk yards, I see that the true '77 engines are much more expensive than the 77 1/2 engines (double the cost).
Are these 2 engines "direct" replacements? Can I buy a '77 1/2 engine and drop it right in for the '77 engine with no issues?
If not, what are the issues I will run into? From what I have read, my concerns are mostly around the exhaust I believe because of some changes in emissions/cats etc etc
Thanks in advance!
PostPosted: Mon Aug 26, 2024 6:05 am    Post subject: Reply with quote
A 77 engine (crank) takes different main bearings which are unavailable. No reason not to go with a later engine up to '82 in the states.
1979 924 NA race car
1982 924 Turbo almost a PoS
chasehubbard
PostPosted: Tue Aug 27, 2024 12:33 am    Post subject: Reply with quote
Understood, thanks for the info, I appreciate it! Just didn't want to purchase an engine and then be stuck with a ton of unexpected work!
