Mbean
Posted: Thu Aug 15, 2024 11:11 pm Post subject: Hot start issue |
My 931 has the hot start issue. I’ve replaced the accumulator, check valve, had vacuum lines replaced and it has new injectors. Starts great cold, runs really well but 15 minutes after shut down it doesn’t want to start. The funny thing is it starts great cold with the cold start valve disconnected. Does this make sense? System and running pressures were within spec when tested by my mechanic. |
