Seamless, bolt-on, plug-in EFI kit for the 924/931/928
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12  Next
mrborrie
PostPosted: Thu Jul 04, 2024 8:19 pm    Post subject: Reply with quote
What actually happens with the fuel relay in this setup. Since its a safety relay to turn the fuel off in case of engine stall.
This now can be done via the BDP sensor correct? The + fuel wire from the ignition can now be routed directly or is it still needed?
760 Turbo |Volvo 360 cup|Volvo XC90 04|Porsche 986S|Porsche 924 79|
safe
PostPosted: Thu Jul 04, 2024 8:25 pm    Post subject: Reply with quote
The ECU controls the fuel pump and turns it on and off. You still have a relay , but a normal one for the current. Basic EFI.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
PostPosted: Thu Jul 04, 2024 8:32 pm    Post subject: Reply with quote
Currently the setup is that the ecu provides tach signal to the tach and to the fuel pump relay, that signal keeps the pump running, its exactly the same as the oem, just that the signal comes from the ecu and not from the coil.
PostPosted: Wed Jul 31, 2024 11:06 pm    Post subject: Reply with quote
Just finished the tune for the 931 EFI setup, it made 170hp at 5500rpm and 237Nm at 4000rpm.
This is what the 931 ecus will come with.
From here you can lean the mixture a bit, as it is running high 10s AFR, and you can also increase the ignition advance as it is running a conservative 19deg.
The settings set i provide is a very safe one, very similar if not identical to the factory one.
My aim was to replicate the OEM performance, so i'm also replicating the oem AFR and ignition curve in the upper RPM.
My 931 has sat since the late 90s or early 2000s and must have a total of 2-3h of running since started on EFI, and on a bore inspection it still has the ring rust marks as it sat, and still made the 170hp and 237Nm on a dyno that is known to never show more hp.
No knock, everything smooth.
So there is still some performance on the table as it is now, even more if you add an intercooler.
I think this is a good base setup that can be either enjoyed as it is in stock trim or built uppon should you want more power.
I will be driving this car for a couple more weeks to keep an eye on it and refine some transition areas of the maps and settings but after that, the project is completed.
barnwerks
PostPosted: Thu Aug 01, 2024 9:09 am    Post subject: Reply with quote
This is great news!
Got to save up some beans over the next couple weeks
PostPosted: Fri Aug 02, 2024 7:02 am    Post subject: Reply with quote
I really like this since you make it so simple and straightforward
Curious about mpg as you continue to test and tune but you might not be testing like that
PostPosted: Fri Aug 02, 2024 3:46 pm    Post subject: Reply with quote
Thanks Mike.
I can and will do a certain speed calibration, meaning i'll drive to 90km/h on a flat and see where that puts me on maps...and set that area of the map to run fuel efficient....i'll do the same for 120km/h and that should be good for cruising.
Other than that the maps need to be fairly smooth to avoid funky behavior.
I have 2 more weeks to optimize the 931 maps.
The SC and NA maps i'll be able to further optimize starting with end of September when i get my 924 back in once piece.
Abet
PostPosted: Sat Aug 03, 2024 6:34 am    Post subject: Reply with quote
This looks like a great solution to end my 924 woes. Can't wait to get my hands on the kit.
Cheers Bob
1981 924 Turbo
PostPosted: Mon Aug 05, 2024 9:37 pm    Post subject: Reply with quote
First drive to actually enjoy this car...until now it was just development, tests and more development. Car pulls very strong and consistent, feels very capable and lag is minimized.
I also did some brief adjustments of the cruise fueling.
Abet
PostPosted: Wed Aug 07, 2024 4:40 pm    Post subject: Nice View Reply with quote
Looking good, glad it is working well.
1981 924 Turbo
PostPosted: Wed Aug 14, 2024 6:03 am    Post subject: Reply with quote
My turbo adventure comes to an end as the temporary registration plates expire tomorrow and unless i do a permanent registration, i cant get any more plates. The car goes to storage and will be shipped to its old&new owner sometime this year.
Still needs a lot of work, but it is now a solid running car, and the next guy will hopefully continue to bring it back to good shape.
PostPosted: Thu Sep 05, 2024 7:48 pm    Post subject: Reply with quote
I'm starting a new build run of EFI kits 15th of September.
There are some guys already on the list but i figured i'll announce here as well to be able to properly size the the list and build.
Supercharger kits build is running at the moment and should be finished before 15th.
EFI kits are configurable for NA/SC/turbo applications but the configuration needs to be specified at the time of the order.
barnwerks
PostPosted: Sat Sep 07, 2024 7:03 am    Post subject: Reply with quote
Very exciting.
Email sent to get my name on the list.
PostPosted: Fri Nov 15, 2024 8:00 am    Post subject: Reply with quote
Vastly overdue - you've been Stickied.
agfisher
PostPosted: Sat Nov 16, 2024 7:57 am    Post subject: Reply with quote
I really want to move on this!
Just have to wait for the funds to develop. I'm really sick of this hot start problem that will not go away. I have tested everything at least three times and can't track that issue down!
1977 924 N/A Martini Edition
Page 10 of 12
