Blas
Joined: 05 Nov 2002 Posts: 227 Location: Illinois, USA
Posted: Tue Sep 12, 2006 11:53 pm Post subject: cross reference number for Fuel Filter (rear) |
Anyone have a cross reference number for the in-line fuel filter between the tank and the pump at the rear of a 1979-924?
The Porsche # is 477-209-233 but I'm sure Bosch or Purolator has something....
Thanks |
Posted: Wed Sep 13, 2006 12:36 am Post subject: |
The little thing? It's not actually a filter, as I recall, but a baffle to cut down noise. _________________ Vaughan Scott
Blas
Posted: Wed Sep 13, 2006 1:58 am Post subject: |
In on the side - out on the top - PET catalog calls it a filter.....odd...
Part #28 in the PET catalog....... |
D Hook
Posted: Wed Sep 13, 2006 9:51 am Post subject: |
| 924RACR wrote: | | The little thing? It's not actually a filter, as I recall, but a baffle to cut down noise. |
I thought that was the accumulator that cut down the noise by smoothing out the fuel flow and kept pressure in the lines after shut down.
Anywho, I've got a filter back there but I believe it's just a generic in-line filter. Go to Napa or favorite parts store and match it up by dimensions, maybe?
I would guess as long as you don't put something tiny on there made for a motorcycle or a lawnmower, you'd be okay.
*EDIT* I just checked my parts book and it doesn't show it so I'm not sure all models came with it or if my PO added it. It's mounted in the hose between the in-tank pump and the fuel pump, IIRC. _________________ '80 924 n/a SOLD
Blas
Posted: Wed Sep 13, 2006 9:54 am Post subject: |
The rear filter says VDO on it but the numbers can not be read...Anyone got an old one laying around for the numbers?
Thanks |
D Hook
Posted: Wed Sep 13, 2006 9:56 am Post subject: |
| Blas wrote: | The rear filter says VDO on it but the numbers can not be read...Anyone got an old one laying around for the numbers?
Thanks |
If I get a chance, I'll try to get out and check tonight for a number/brand. _________________ '80 924 n/a SOLD |
Stampedetrail
Joined: 29 May 2005 Posts: 274 Location: Fairbanks, Alaska
Posted: Thu Sep 14, 2006 2:37 pm Post subject: |
My car has 2 accumulators... not sure why. One is brand new as of July. _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can. |
Ozzie
Posted: Thu Sep 14, 2006 5:01 pm Post subject: |
Early cars had 2 accumulators of 20cc each.
Later had one 40cc. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Blas
Posted: Fri Sep 15, 2006 2:01 am Post subject: |
May have found a replacement rear fuel filter:
Purolator #F29128 - $3.50
I just need to verify the hose ID sizes....
Unless anyone has the hose diameter information handy...????
I'll post back my findings....after a fit-up.... |
mhariush
Posted: Mon Mar 11, 2024 11:28 am Post subject: |
Very old thread i know, but these are old cars
I'm in the process or replacing this myself... What did you end up doing here? _________________ 78 924, 87 944S, 89 944 Turbo, 08 Cayenne |
