Sunroof Drains
PostPosted: Wed Sep 06, 2023 11:31 pm    Post subject: Sunroof Drains Reply with quote
Could someone post or email me a picture of the location of the sunroof drain tube holes. My car got resprayed prior to my purchase and I have never found the drain holes. It obviously leaks.
Mike
'67 MG Midget Dp
!tom
PostPosted: Thu Sep 07, 2023 3:12 am    Post subject: Reply with quote
They're in the corners... Go directly down the roof support pillars with rubber hoses.
78 924 NA
5-lug
PostPosted: Fri Sep 08, 2023 10:52 pm    Post subject: Reply with quote
Two of us spent quite a while looking for drain holes in the back and couldn't find any. Removed the rubber seal and cleaned the channel. Much more difficult to get to the front. Possibly the '77's didn't have any.
Mike
'67 MG Midget Dp
PostPosted: Mon Sep 11, 2023 11:58 pm    Post subject: Reply with quote
Maybe finally go it figured out. It apears most factory tops were metal, mine is unframed glass so probably a later model Saratoga top, so an add on with no drains. One semi cure is to appy some weatherstripping to the glass rim.
Mike
'67 MG Midget Dp
