vintageant
Joined: 15 Apr 2016 Posts: 35 Location: Miami, Florida
Posted: Tue Apr 25, 2023 11:22 pm Post subject: Headlight motor challenge |
1987 924S. Headlight motor burned out and just installed a replacement, but acting strangely! Haven't tightened down the nut on the actuating arm, but when headlights turned on, lights turn on, but motor does not activate. If the high/low beam lever is pulled the motor activates, presumably raising the lights if the nut were tight. Pulling the high/low beam lever again, and the motor activates again, presumably lowering the lights. Could this be because of a different relay type? Somehow doubtful! I haven't swapped out the old relay as I wanted to check here first. Thoughts? Thanks! _________________ New first time 1987 924S owner - April 2016
1970 VW 'Peking to Paris Rally' Beetle |
