How to check power windows
Topls82
PostPosted: Thu Mar 02, 2023 10:05 am    Post subject: How to check power windows Reply with quote
Guys
My 81 has not been driven for 5-6 years and no battery
In process of restoring all aspects …
But would like to verify if the power window motors are working…
Can this be done with power from my charger to certain pins on plug ?
Tried on the passenger plug/ pins but no operation …thought must be controlled by drivers side ??
Dont want to install the new door card and related till I verify the power windows are operating properly
Thanks for assistance
Frank
!tom
PostPosted: Fri Mar 03, 2023 5:56 am    Post subject: Reply with quote
Passenger window switch is wired in series with the drivers window switch.
78 924 NA
5-lug
Topls82
PostPosted: Tue Mar 07, 2023 9:10 am    Post subject: Power windows check Reply with quote
Ok….figured it out…..
Power to The blue & blue/black wires…(pins in the plug)
Use charger or battery ..
Switch leads for up down functions
This is done with door panel off and switch removed ,so power feed right to the wires at plug
Thankfully both worked correctly
