trybedoor Guest
Posted: Thu Feb 09, 2023 4:56 am Post subject: torque tube bearings in a '80 924 |
Need some help in replacing the torque tube bearings in a '80 924, 4sp.
The mechanic took it off, but he still has to figure it out, how to replace those bearings inside the housing.
Any helpful suggestions? |
Joined: 08 Jun 2010 Posts: 1246 Location: Maysville, Colorado
Posted: Fri Feb 10, 2023 10:35 pm Post subject: |
If you look up clarksgarage.com which is for the 944 primarily, in the maintenance area there will probably be a write up of the process, I believe it is a rather involved scheme. Be aware that if any bearing part numbers are given, they will not work with the 924 as the shaft size is 4mm smaller. _________________ Mike
'67 MG Midget Dp
Brian L.
Joined: 10 Jul 2006 Posts: 127 Location: Buckley Washington, USA
Posted: Thu Feb 16, 2023 3:16 pm Post subject: tt bearing |
I have a 944 torque tube but I don't know its history and I may be performing this task in the future. I recently spotted this thread and its one of the more in depth that I have found.
https://forums.tipec.net/viewtopic.php?f=25&t=25010 _________________ 1980 924 N.A. Monaco Blue owned since 1987
"Remember, sitting on your ass won't finish your project" -Puddins fab shop. |
Posted: Fri Feb 17, 2023 12:12 am Post subject: |
Just make sure you guys pay attention to Torque Tube Shaft Size
See here
https://www.924board.org/viewtopic.php?p=218956#218956 _________________ 1980 931 since 1989
Brian L.
Posted: Fri Feb 17, 2023 3:42 am Post subject: torque tube shaft dia. |
Good point Mike, the 944, 924s and the 924 turbo share the same drive shaft dia. (25mm)
vs the 76-82 924 that had the smaller drive shaft (21mm). My 944 tt is for a future project, I guess I should of made the difference clear in my prior post.
I am surprised that Trybedoor's 1980 is equipped wirh a 4 speed transmission. _________________ 1980 924 N.A. Monaco Blue owned since 1987
Mclaren924
Joined: 13 Oct 2021 Posts: 265 Location: Oceanside CA
Posted: Fri Feb 17, 2023 1:01 pm Post subject: Re: torque tube shaft dia. |
| Brian L. wrote: |
I am surprised that Trybedoor's 1980 is equipped wirh a 4 speed transmission. |
Just swapped my 77 with a 5speed turbo transmission, believe it came out a 81 turbo but I wound up using an old mustang clutch that had the same spline count and disc size and it fit like a glove! Think you can wind up mating any of the late style tranmissions as long as you sort clutch out. _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Brian L.
Posted: Fri Feb 17, 2023 2:54 pm Post subject: Re: torque tube shaft dia. |
| Mclaren924 wrote: | | Brian L. wrote: |
Just swapped my 77 with a 5speed turbo transmission, believe it came out a 81 turbo but I wound up using an old mustang clutch that had the same spline count and disc size and it fit like a glove! Think you can wind up mating any of the late style tranmissions as long as you sort clutch out. |
Hey McLaren did you swap out the torque tube also? If so what year mustang and engine size was that clutch disc out of? I hear that a bronco II disc will also work. _________________ 1980 924 N.A. Monaco Blue owned since 1987
Mclaren924
Posted: Sat Feb 25, 2023 4:21 am Post subject: Re: torque tube shaft dia. |
| Brian L. wrote: | | Mclaren924 wrote: | | Brian L. wrote: |
Hey McLaren did you swap out the torque tube also? If so what year mustang and engine size was that clutch disc out of? I hear that a bronco II disc will also work. |
Yup swapped TT as well, PN is LUK-07-003. If you are running a turbo pressure plate than yes those bronco style ones will work, I am running an NA pressure plate so the mustang one was the only option. Small diameter difference between the two. I didn't have a good turbo Pressure plate and had a cherry NA one laying around so thats why I went this way. _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
Far2Gone
Posted: Mon Mar 13, 2023 5:48 am Post subject: Torque tube |
Hello,
I have an 82 924 NA, of all the very limited information I can find on TT bearing removal and replacement I have never seen or heard anyone have this 'spacer" nor can I find any info on it even with the part number stamped into it. When I find new complete bearings (probably Constantine's super bearing) should I be able to delete this part? I ask because it has a lot of weight for it's size and do not want to do this job twice because of some weird balance issue.
Thank you for the assistance.
https://drive.google.com/file/d/1QYnIiXCoNv8an5mJ_LH07xBNYM4VwGjY/view?usp=sharing |
Posted: Mon Mar 13, 2023 6:04 am Post subject: Re: Torque tube |
| Far2Gone wrote: | Hello,
Its a vibration dampener, found one in mine too. Can probably be deleted it weight is important. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
Posted: Fri Mar 17, 2023 7:50 am Post subject: |
Agree, its the tuned frequency damper and you can probably just leave it out
Technically it was put there for future changes in the car like a new clutch that wasn't balanced. The beauty of these cars is that you can just balance the rotating parts by themselves as they are replaced _________________ 1980 931 since 1989
