Fuel pump wires
chardorcher
PostPosted: Sun Jan 29, 2023 12:48 am    Post subject: Fuel pump wires Reply with quote
There are 2 wires at the rear which connect to the pump, a brown and black one, Am I correct to say that the Brown is positive? Also why does the pump still seem to turn when bench tested and wires are altered around? Thanks guys.
MANY CARS
PostPosted: Sun Jan 29, 2023 10:16 pm    Post subject: Reply with quote
No, brown is basically always ground on German cars.
Don't forget to check your grounds...
chardorcher
PostPosted: Mon Jan 30, 2023 9:09 pm    Post subject: Reply with quote
Thanks my friend, a friend of mine suggested an extra strap from the engine block to the chassis/body, I guess this will do, as for other earths we have thoroughly cleaned and changed any loose connections, wires etc. Still more work to do....
MANY CARS
