Posted: Sun Nov 27, 2022 6:23 am Post subject: |
kondzi wrote: | Mike9311 wrote: | Carrrera, I've been reading this thread and I can tell you are older.
ROTFL
Cedric wrote: | buy a cheap audi turbocharger and take the compressor from(and put on your current turbo) if you find it to much of a struggle to fit the piping to the original one |
Which exactly? |
Most of the K26 turbos that looks like the on in jacobs link works. But if you have the smallest k26 2660 and want to keep the wheel you have to search for the turbos which have the same wheel size.
I mean the list is pretty massive, this is just part of it
If you want the slightly bigger wheel and housing the sk 2664 wheel heres some of them
check what you can find locally, the part number is easy to check up. _________________ 1980 924 Turbo |
Joined: 08 Jan 2010 Posts: 2287 Location: Somerset, UK
Posted: Sun Nov 27, 2022 6:54 am Post subject: |
Not sure how I should take this .....
Here's an interesting thread, cannot believe it was started 10yrs ago now, showing my age!! - http://forums.tipec.net/viewtopic.php?f=25&t=13106&hilit=modifying+924+turbo . I was very much a newbie and asked many questions still being asked now. Hope it helps a little _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Joined: 14 Dec 2004 Posts: 1512 Location: Chicago-ish
Posted: Tue Nov 29, 2022 2:09 am Post subject: |
Carrera RSR wrote: | Mike9311 wrote: | Carrrera, I've been reading this thread and I can tell you are older.
Here's an interesting thread, cannot believe it was started 10yrs ago now, showing my age!! - http://forums.tipec.net/viewtopic.php?f=25&t=13106&hilit=modifying+924+turbo . I was very much a newbie and asked many questions still being asked now. Hope it helps a little |
It was a compliment in that you are wiser and had time to reflect on what you have done. Even though you trail-blazed some really really cool ideas in your build, you still look back with some nostalgia to say 200-225 can be enough. That there there is something to be said on waiting for "S1-like" boost to come on. Oh I will add the smell, lets not forget the smell
Your threads help many more than you may know
I need to look up the PN but its likely easy to find
The billet drop in upgrade for the 2660. It was supposed to have been tested this late summer / fall but we tagged on a small extra project on car reassembly that didn't beat the salt trucks around here. Waiting until early Spring. 10 PSI 2660 with Dan's LA TMIC. If everything runs nice, I'll get it dynoed for kicks
Posted: Tue Nov 29, 2022 5:22 am Post subject: |
Yeah it could definitely be a good idea to upgrade the wheel, hopefully they should flow a bit more since the blades are thinner, they are often pretty decently designed aswell. I use a billet wheel in my 2670 compressor, since the original one had a damaged blade, though this was a batch ordered by a turbo shop, maybe they are readily available nowadays. Im very happy with the turbo+IC setup, boost comes on quite a bit earlier in the rev range than before(according to but dyno and logs , havnt been to the dyno after upgrades due to my engine build ), and then pulls hard all the way to red line, even though the turbine and compressor is significantly bigger. _________________ 1980 924 Turbo |
Posted: Tue Nov 29, 2022 5:47 am Post subject: |
Awesome
What I noticed on all the billet wheels is that the blade root is deeper or maybe I should say, they have a slimmer-hub so the blade surface area is larger and the inducer opening could then be larger 'to the inside' or toward the shaft, if they
carry the reduced hub diameter up to the nose by the nut.
Its like getting a larger inducer opening without actually going larger on the diameter. Subtle yes but free to take advantage of a millimeter or more
Its good to hear you say they can be decent in design _________________ 1980 931 since 1989
kondzi
Posted: Wed Nov 30, 2022 1:41 am Post subject: |
Guys can you identify what turbo I have based on these photos?
If not, what /where I need to look for to identify what turbo is it?
Not sure when I will be nearby my garage (currently 200km away). _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Wed Nov 30, 2022 1:49 am Post subject: |
So I am very sure you have a 6.10 Turbine Housing (that's really good news for you)
The other number on the bottom of the tag could be 266027
So it might be a 2660 Compressor with a 6.10 exhaust
I'm going by the location of triangular logo.
6.10 Left / 4.10 Right
kondzi
Posted: Wed Nov 30, 2022 1:59 am Post subject: |
On the exhaust propeller there is 12 blades if that clarifies anything (found another shot). I will try to upload more photos I found on my laptop shortly. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Wed Nov 30, 2022 2:25 am Post subject: |
The best would be a camera down the inlet compressor side
With your pistons and 6.10 housing you might have the Euro S1 compressor which you will want to change for sure
Its the smallest one of all of them and looks old school when you see it.
This is all I could post quickly. A bit beat up
Posted: Wed Nov 30, 2022 2:45 am Post subject: |
The turbo rebuilder seems to have removed the orginal tag, a bit unfortunate.
here you can see the size and connector differences between the 931 and 944turbo/audi etc.
heres a better picture to illustrate the wheel difference, the one to the right is the very ancient wheel thats originally on the euro s1. the left is from 951, but the outer diameter and design of the blades is similar to the other more modern 931 versions.
Posted: Wed Nov 30, 2022 2:48 am Post subject: |
yes mike, regarding the center hub of the wheel. Roughly the flow capability is set by the smallest area between the blades, so narrower hub in combination with thinner wheels should be able to flow more in theory (other parameters can affect this aswell) _________________ 1980 924 Turbo |
Joined: 05 Jun 2006 Posts: 1469 Location: Ontario, Canada
Posted: Wed Nov 30, 2022 5:27 am Post subject: |
FYI if you are going for a turbo rebuild, in addition to the newer/better design compressor wheel, there is also a newer/better design and much lighter turbine wheel with shaft. _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
kondzi
Posted: Wed Nov 30, 2022 5:39 am Post subject: |
Good stuff guys about comparing the S1 turbo with 951.
Adding photos in high res of my engine where turbo is visible.
Maybe that helps to identify the cold side, as it seems the hot side is 6.10 when looking at Mike's photo.
I may ask my father to measure something over the weekend, but it seems without looking inside there is no way to distinguish S1 and S2 turbo as the housing is the same (2660), just the compressor wheel is different?
Sorry for silly questions, but for me I can distinguish small turbo, medium turbo, bi-turbo and a big turbo
So when I finally identify what I have, we'll discuss the upgrade options hopefully
Konrad
'89 951 US
'81 931 RoW (TBD)
