gorogorogo
Joined: 10 Nov 2020 Posts: 7 Location: Ontario, Canada
Posted: Wed Oct 05, 2022 3:35 pm Post subject: Converting Banjo-bolt injector lines to coupling-end type? |
This has probably been covered before, but I was not able to find the relevant information on this site.
I've got 1978/79 (the ownership says 1979, but it might be one of them .5 transitionary production date type of deals) 924. It's got the braided stainless lines with banjo-bolt fittings to attach them to the injectors.
Based on the service information it seems like injectors are the source of my problems, so I went out and got new injectors using the part number specified by Bosch (there isn't a listing for anything prior to 1979). It needs a different fitting that what is on my car.
Since the lines I have (apart from not fitting the new injectors) seem to be alright, I was wondering if it is possible to swap the hose ends. I've been searching around and I haven't found a definitive answer (because I don't know what exactly it is I'm looking for if it is possible). |
Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Wed Oct 05, 2022 7:06 pm Post subject: |
I'm not sure that is what I would do..
Why don't you sell the injectors you have to somebody with a later car and buy 4x 047 133 551 instead ( part no. assuming you have an N/A car)? These will fit your injector lines.
Auto Atlanta has a picture for you to look at
Eliza _________________ 1985 924 NA RoW
1981 931 S2 RoW |
gorogorogo
Posted: Thu Oct 06, 2022 7:20 am Post subject: |
| I may end up doing that. The reason I bought the injectors is because they are brand new (I think the manufacture date is 2021), and I didn't have to get NOS injectors from eBay -> Canada. If I can get the ends sorted out, I won't have to worry about tracking down NOS injectors (it doesn't seem like Bosch makes a replacement for the banjo-bolt style of injectors). |
