Euro924S2
Posted: Thu May 26, 2022 7:30 am Post subject: |
Hi. Yes, those are the ones. They do them in 5x130 for porsche wheels which would make life easier. They are way too in-board for standard wheels and brake discs etc. I have 9J rears (245 40 17 tyres) with the standard narrow 924 arches and they just fit under with no rubbing. The wheels are +38 offset IIRC.
The disc is ‘floating’ as you say, being clamped between the hub and the wheel. The fiat ducato front brake discs have an offset which puts them pretty close to the stock position of a 944 S2 or turbo disc so those calipers mount up to the stock bracket with minimal shimming needed.
The handbrake has been a massive headache!! I too legally need a mechanical handbrake so I’ve modified the 944 system to work. I modified standard 924 drum shoes to form a tighter radius and the bow-arm thing to take up less space.
I would advise against all of this and use some wheels which have a more sensible offset, use standard 944 rear discs and handbrake setup and space the gap between the hub and the disc if that is possible. (The problem might be that the handbrake bow-arm is trying to rub against the hub as it’s all trying to occupy the same space!)
The above is not me suggesting you follow my path, more to warn you against it! I’ve changed a lot on my car over the years and the handbrake mechanism has been one of the most annoying to get right! It’s now ‘pretty good’ and passes the MOT (safety inspection) every year and is functional on the road, but it certainly won’t be performing any skids!!
I can’t share photos on here - no photobucket etc account, but DM me your email and I can share what I have (and you’re welcome to post them up here to share).
Cheers,
John. _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
F3ARED
Joined: 14 Feb 2022 Posts: 29 Location: Melbourne, AUS
Posted: Mon Jul 11, 2022 9:28 am Post subject: |
Have been a little bit lazy. For anyone interested, heres the photos John sent me of how he converted the rear drum to disc hub.
May be of help to someone. I ended up getting my hands on a full set of 5 stud hubs....wallet is still recovering [the freight was more expensive than the bloody hubs!]
N- _________________ 1977 Porsche 924
1987 Range Rover Classic 3.5L V8 |
kondzi
Posted: Mon Jul 11, 2022 6:32 pm Post subject: |
^^^ what a brilliant idea _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Tue Jul 12, 2022 4:24 am Post subject: |
I second that! Nice thinking and execution! _________________ 1980 931 since 1989
Euro924S2
Posted: Tue Jul 12, 2022 5:21 am Post subject: |
Cheers guys. Worth noting that these blank drums came from www.machine7.co.uk in the UK. They do a 5x130 Porsche PCD off the shelf, but these are drilled to 5x114.3 which is popular Jap car (Mitsubishi, Toyota etc) pattern so they will fit my forged SSR wheels. Clearly not many folk fit Jap wheels to their beetles so they don’t cater for that PCD off the shelf.
The challenge once you’ve made the hubs is then finding a disc which will work with your calipers and brake shoes (if running a drum type handbrake).
Your 5 stud setup might have cost you a lot inc shipping, but it’s saved you a fortune in pain killers which you’d have consumed with all the headaches this DIY setup causes!! _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
madislandguy
Joined: 25 Nov 2009 Posts: 26 Location: Madeline Island, WI and Elburn IL
Posted: Tue Jul 12, 2022 5:35 am Post subject: |
Machine7 appears to have closed down their shop last month according to the web site. |
Euro924S2
Posted: Tue Jul 12, 2022 5:41 am Post subject: |
Gish, you’re right, and they don’t even seem to be fulfilling orders placed and told customers to contact their card providers! That’s not good! Shame, I had a great service from them. I suspect there will be a lot of stock getting auctioned off there! _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
