Have to press clutch pedal to floor to engage gears?
mungodrums
PostPosted: Mon Nov 15, 2021 3:05 pm    Post subject: Have to press clutch pedal to floor to engage gears? Reply with quote
I was wondering if one needs to press clutch pedal in 88 924 all the way to the floor before changing gears or can I change gears with no issues, grinding by only pressing it half way or so? Seems like travel is quite long. Ger.
Riggard
PostPosted: Tue Nov 16, 2021 3:27 am    Post subject: Reply with quote
Really depends on your cable adjustment and clutch wear. But in my case (really worn clutch) all the way to the bottom is the only way.
