Posted: Sun Oct 31, 2021 5:06 am Post subject: |
Oh wow! that looks so good! _________________ Supercharger and EFI kits
https://www.the924.com |
Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Sun Oct 31, 2021 2:45 pm Post subject: |
Thanks!
I was astonished how relatively easy this turned out to be. Morghen, I'm glad you pushed me to use a modern fan, rather than trying to fit the later-style blower. You gave me just the encouragement I needed!
Eliza _________________ 1985 924 NA RoW
1981 931 S2 RoW |
Eliza
Posted: Sun Oct 31, 2021 2:55 pm Post subject: |
| morghen wrote: |
EDIT: Can i see some pictures of your 85? Mine has some small differences from the 84 and older 924s and i'm wondering if they were all made the same in 85. For example, heated windscreen sprinklers, electric boot opener like the 944, 944 sway bars, one additional frequency valve on the CIS. |
BTW, the frequency valve... do you mean the hot start valve ("Supplementary start valve" as per wiring diagram)? Under the fuel distributor? That one is installed in my car. I assume it may be stock for an 85, looks factory installed. I tested it, it's an electric valve that lowers fuel pressure on hot starts.
1981 931 S2 RoW |
Posted: Sun Oct 31, 2021 6:16 pm Post subject: |
Yeah i meant that valve, i have it as well on my 85. Has never had a hot start problem and the fuel accumulator is surely dead by now.
Happy to see that this thing with the fan turned out so well, cant wait to do this mod for my buddie's 924.
Thank you for trying it and especially for sharing with our community. _________________ Supercharger and EFI kits
Posted: Sun Oct 31, 2021 6:44 pm Post subject: |
It also looks like a perfect place for using my 3D printer to make a neat fan adapter plate.,now ill just hope that my fan breaks 😂
I already changed the fan with the hack and glue back method many years ago, it was quite easy to do, but this is neater. And more flow is definitely needed on hot days. Now to the problem with the ridiculously awful connections beteende the air hoses and the heater core(that always pops of) , were those changed for the later cars? _________________ 1980 924 Turbo
Eliza
Posted: Mon Nov 01, 2021 3:20 pm Post subject: |
Cedric,
yes they were . I changed the plumbing between the heater box and the under dash hoses with parts off of the later heater box (later 924 and early 944) , see post 7 for pictures.
Although I did this to get heat out of the dash vents, this mod also replaces the crappy connections between center and side dash vents, those oddly shaped thingies that keep popping off and are impossible to seal tightly.
1981 931 S2 RoW |
DZGunner
Joined: 18 Nov 2014 Posts: 191 Location: Great white north
Posted: Tue Feb 22, 2022 3:53 am Post subject: |
So what actual part (fan) did you actually order? your listing says VA40-A100-76A, but the picture you posted of installing says VA39-a101-45a. _________________ 1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts) |
Riggard
Joined: 16 Feb 2021 Posts: 90 Location: Heemskerk, Netherlands
Posted: Tue Feb 22, 2022 7:50 am Post subject: |
| Nice job! |
Eliza
Posted: Tue Feb 22, 2022 3:27 pm Post subject: |
| DZGunner wrote: | | So what actual part (fan) did you actually order? your listing says VA40-A100-76A, but the picture you posted of installing says VA39-a101-45a. |
I ended up with the VA39-A101-45A. The other one seemed a bit on the large side. Good thinking, from hindsight - I needed a bit of space to route the wiring between the housing and the fan
1981 931 S2 RoW |
DZGunner
Posted: Tue Feb 22, 2022 10:34 pm Post subject: |
Sweet, thank you. I went ahead and ordered one. I was driving through the winter storm from cody to billings, and my blower motor went out right as i left cody. needless to say it was a miserably cold trip lol _________________ 1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts) |
