ideolas compression calc
anthonimartini
PostPosted: Sat Mar 27, 2021 3:02 am    Post subject: ideolas compression calc Reply with quote
recently somebody posted a mirror to dans old compression calculator. i need this tool to finalize some calculations before i order parts. anybody have that link?
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
PostPosted: Sat Mar 27, 2021 5:26 am    Post subject: Reply with quote
http://924.terribly.fun/compression/
anthonimartini
PostPosted: Sat Mar 27, 2021 9:52 am    Post subject: Reply with quote
i have that one i thought there was another version that had a option for the 931and vw flattop combo. is was hosted bu thewayback machine i think.
current:
83 944
87 924S
jacobroufa
PostPosted: Sun Mar 28, 2021 2:17 am    Post subject: Reply with quote
I own the 924.terribly.fun domain -- I snagged a bunch of the calcs off of Dan's site before it went down. Let me look and see if I can find the one you're talking about...
If you go to the index by the way, you can see all that is there. http://924.terribly.fun has a listing and it is mostly spreadsheets. The code for the calculator was some wysiwyg generated thing; there might be an option commented out that I can try to find.
1980 Porsche 931
1981 Porsche 924 Weissach
safe
PostPosted: Sun Mar 28, 2021 7:23 pm    Post subject: Reply with quote
Just change the piston dish volume to 0 and the compression height to that of the flat tops.
But the calculator is just an approximation. For accurate numbers you will have to measure actual parts on the actual engine.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
anthonimartini
PostPosted: Mon Mar 29, 2021 2:22 am    Post subject: Reply with quote
yeah i have ordered a burette so i can see what my head volume is. im ordering the 88mm pistons on monday. ill rough assemble my engine soon and see what it actually is. if the compression is too low ill get the block decked. this is all going on a block that has bad std bores so it needs to be bored out to 88 first. it seems i hit a dead end on using the bmw rods with the big end being way too narrow. i could probably run them with no real ill effect but im just going to lighten to stock rods and rebush.
current:
83 944
87 924S
PostPosted: Thu Apr 29, 2021 12:19 am    Post subject: Reply with quote
When doing a piston also think about crevice volume before the top ring
looks like this. The outer ring around the bowl
