ignition issues
pierro
PostPosted: Tue Mar 02, 2021 9:00 pm    Post subject: ignition issues Reply with quote
Busy with renewal of the spark plugs, cabels and distributor and found the following on the existing items;
Spark plugs with built-in resistor (Bosch WR6)
Cables (Bremi) with 1Kohm and metal plug of 5Kohm
Bosch rotor with 1Kohm of resistance .
Is this all to original specs ?
To me it seems a lot of resistance all together
What do you guys recommend, which type of spark plugs and set of cables for my 1983 924 with 2.0 engine
Awaiting your suggestions
Porsche 924 1983restored
MG-Midget 1974 restored
Citroen 2CV 1986 restored
Rover Mini 1275 1992 restored
Mazda MX-5 1.8 for the fun
Toyota Lancruiser Prado daily driver
Merceds Benz W124 230E for the quality
safe
PostPosted: Wed Mar 03, 2021 12:09 am    Post subject: Reply with quote
I would rather go with NGK BPR6ES, its equivalent to WR6, but I have had better luck with NGK.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
pierro
PostPosted: Wed Mar 03, 2021 1:13 am    Post subject: Reply with quote
Thanks Magnus for your swift response.
Do you have sparke plug cables with or without resistance?
safe
PostPosted: Wed Mar 03, 2021 1:31 am    Post subject: Reply with quote
Both the Bosch and NGK has a resistor (indicated by the R) to help and suppress electronic interferance.
I have MSD wires that has carbon core wire so they have a high resistance compared with copper core wires, But my ignition system is not stock.
In general you want as low resistance as possible for maximum energy to the spark plug, but carbon core wires works well in the 924.
Porsche 931 -79
