Posted: Fri Jul 10, 2015 6:48 am Post subject: |
Mount fails... I do a lot of my math on the bench with soapstone and stop my grinder on it all the time in that area too..
Mount Success!!
Ah, see there leadfoot that isolator mount on the bottom left of this pic that my sister crossthreaded, that's the one I was talking about..
Looks like a job for the shop vac.. _________________ 80 Turbo - Slightly Modified
Last edited by Fasteddie313 on Fri Jul 10, 2015 7:31 am; edited 3 times in total |
Posted: Fri Jul 10, 2015 6:51 am Post subject: |
Yes I saw his remote mount control pressure gauge, not until after I started mine though..
IIRC there is no valve that allows you to see system pressure in his version, or am I mistaken? _________________ 80 Turbo - Slightly Modified |
Posted: Fri Jul 10, 2015 7:59 am Post subject: |
Exact gauge, valve, compressions, and Tee assembled cleanly with teflon tape, correctly indexed, and modified $40 shipped..
With mount fabbed and installed on gauge assembly with all bolts cut to fit (drill your own bottom mount bolt hole in situation, to fit 931 only??) + $20 shipped.. (Only available with gauge assembly or extra shipping will be needed)
Send me your WUR line for cutting and bending, install gauge assembly, mount if requested (still drill your own bottom hole in situ), including a pressure test up to my system pressure, and return shipping (price may go up if your WUR line cannot be made to seal, IDK, but only for pieces to correct the situation, free labour, for 931 only) + $25
I assume no liability for blah blah fine print NONE under any circumstances.. _________________ 80 Turbo - Slightly Modified |
Posted: Sun Jul 12, 2015 4:41 am Post subject: |
MikeDanger
Posted: Fri Feb 26, 2021 11:27 am Post subject: |
all these pics don't load any more _________________ It was either this or a giant box of legos |
Posted: Sat Feb 27, 2021 12:49 am Post subject: |
| MikeDanger wrote: | | all these pics don't load any more |
Yeah..
photobucket screwed everything up..
Their is a way to do it but I don’t know how.. _________________ 80 Turbo - Slightly Modified |
MikeDanger
Posted: Sat Feb 27, 2021 4:01 am Post subject: |
heres what I do, shhhh dont tell any one..
I post pics on rennlist 924 forum, and just copy them to here _________________ It was either this or a giant box of legos |
