Lighting issues, '77 924
felix83
PostPosted: Thu Mar 05, 2020 11:22 pm    Post subject: Lighting issues, '77 924 Reply with quote
Hi all,
I recently purchased one of my dream cars, a 1977 924 Euro spec.
It's to be considered a non runner, the engine runs OK but everything else needs looking over.
My main focus is to get the electrics fully working, and my second port of call (after re-soldering the hacked-up light switch socket) is the following:
(I've marked my questions in bold type, any input is highly appreciated!)
- Indicators not working. When turning on the indicators the green light stays on. (I haven't thought of checking whether the indicators themselves light up at all). The parking lights light up on the corresponding side when using the indicator stalk with ignition off, as they should.
- Hazards work, indicating the flasher itself works (right?). The frequency of flashing is normal.
- The flash-to-pass works, both with lights off (lights in bumper turns on) and on (main headlight turns on), but the high beams won't stay on. Am I right in thinking they should switch on when pulling the stalk towards the wheel, and turning back off when repeating the same motion?
- None of the instrument lights work
- Horn doesn't work
- Wipers don't work
I'll start by replacing all fuses and cleaning up the terminals in the fuse box, but since the hazards work OK, I think the problem lies elsewhere.
I'm suspecting the steering column switch to be defective, could that explain some of my issues?
Like I said; all input is greatly appreciated!
Felix
'77 924
'82 911 SC
Instagram: @orebro.classics | @924.resurrection
felix83
PostPosted: Fri Mar 06, 2020 4:24 pm    Post subject: Reply with quote
I've done some digging, and as far as I can make out, there is no flash-to-pass on the 924. What's likely my issue is the high beam switch itself. Hopefully I'll get some time to look into it this weekend.
Felix
'77 924
'82 911 SC
PostPosted: Fri Mar 06, 2020 4:48 pm    Post subject: Re: Lighting issues, '77 924 Reply with quote
yes, pulling the stalk until it clicks will either turn on or off the high beams.
Nice color car.
felix83
PostPosted: Fri Mar 06, 2020 8:59 pm    Post subject: Re: Lighting issues, '77 924 Reply with quote
Nice color car.
Thanks for your input! The colour is an old (~30 years) respray, originally it would have been silver only. But I like the patina!
Felix
'77 924
'82 911 SC
PostPosted: Fri Mar 06, 2020 9:22 pm    Post subject: Reply with quote
Yeah, looks cool.
What are your plans for it?
felix83
PostPosted: Sat Mar 07, 2020 12:02 am    Post subject: Reply with quote
Yeah, looks cool.
First of all, getting it to work properly. After that I'm probably just going to enjoy it. I've nicknamed the car "Project old man spec", since I'll make it just that. I'm looking for an original two spoke steering wheel, and the steel wheels are staying!
Felix
'77 924
'82 911 SC
PostPosted: Sat Mar 07, 2020 7:20 am    Post subject: Reply with quote
Can we get a detailed shot of the torsion bar access hole your cars appears to have right in front of rear wheel ?
felix83
PostPosted: Sat Mar 07, 2020 7:38 am    Post subject: Reply with quote
I'll snap some photos when I get the chance. Do you want pictures of the hole itself or just the cover plate?
Felix
'77 924
'82 911 SC
PostPosted: Sat Mar 07, 2020 7:41 am    Post subject: Reply with quote
Both please, thank you. Just want to see how it was done
Nobbi
PostPosted: Tue Mar 10, 2020 7:42 pm    Post subject: Reply with quote
i think the car has the stock steel rims on, very rare item here in Germany.
These were Standard but most customers went for the Aluminium wheels.
NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew..Plus : DEUTZ 4005 tractor Built 1967
felix83
PostPosted: Tue Mar 10, 2020 7:58 pm    Post subject: Reply with quote
The same is true for Sweden!
Felix
'77 924
'82 911 SC
PostPosted: Wed Mar 11, 2020 11:21 pm    Post subject: Reply with quote
And OZ. I have never seen 924 steel wheels......actually quite pleasant.
