Opinion on suspension...
Kenodog
PostPosted: Mon Mar 11, 2019 11:29 am    Post subject: Opinion on suspension... Reply with quote
So I thought I had a new set of Koni rears to go with the new fronts I have but it turns out they are another set of the adjustable fronts. Grf. So. Do I buy a set of Koni rears to match the fronts or use a new set of Bilsteins I have sitting on the shelf ?
Im not sure if mixing different brands will have a detrimental effect on the handling.
Me
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
K-Roll931
PostPosted: Mon Mar 11, 2019 12:48 pm    Post subject: Reply with quote
Could be an interesting test to see how different brand suspension parts can/cannot go together... Personally, I'm running Sachs up front and eventually KYB in the rear. Completely different tier of shocks/struts, but your inquiry in reality.
'80 931 M471 - Dolomite Gray -> Monaco Blue
PostPosted: Mon Mar 11, 2019 2:06 pm    Post subject: Reply with quote
There will be substantial differences between the brands!
Konis are oil...Bilsteins are gas. Never mind what the rates of deflection are.
Performance oil shocks will initially be harsher when cold, until you've put a few miles on it to warm up the oil. Gas will work just right from the get-go.
That apart, for ideal compression and rebound rates, the shocks within each brand need to be matched....refer manufacturer's specs.
Both brands however can be revalved and rebuilt.....they are quality brands.
For my money, I prefer gas over oil.
One of my Toofahs runs Bilstein, while my Forfah runs adjustable Konis.......both with similar spring rates, and supposedly shock rates. The Toofah wins hands down! On every metric!
PostPosted: Mon Mar 11, 2019 5:13 pm    Post subject: Reply with quote
No, both are oil based dampers, one of them is pressurized, but that is to counteract cavitation. In theroy they could be valved very similar. But they obviously arent..
It depends how picky you are, and if its for street driving or track driving. They arent worlds apart, but its also very subjective with things like this, something that is horrible for someone could be absolutely fine for a different person.
Johann
PostPosted: Mon Mar 11, 2019 7:49 pm    Post subject: Reply with quote
I am running Bilstein B6 on my 931 and am very satisfied. Fits under the hood with no clearance issues and the green shocks poking out from under the back looks quite cool.
PostPosted: Mon Mar 11, 2019 8:08 pm    Post subject: Reply with quote
Johann wrote:
......... and the green shocks poking out from under the back looks quite cool.
Must have a high rear end??!!
Johann
PostPosted: Mon Mar 11, 2019 10:51 pm    Post subject: Reply with quote
I'm running stock height and that is pretty high...I am thinking of lowering it though, but that is a slippery slope.
Kenodog
PostPosted: Tue Mar 12, 2019 2:35 am    Post subject: Reply with quote
The problem is that I have the front Konis in custom modified 924S strut housings so I can bolt up the 951 Brembos. Removing them for the Bilsteins would be a pain. And.. it would leave me with two sets of front Konis I have no use for, was just trying to use them up and get them off the shelf.
Frickn frack
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Tue Mar 12, 2019 5:26 am    Post subject: Reply with quote
You could just try the konis on front and bilsteins on the back to see how it feels.
Maybe you will find that you like the way the front of the car feels and go with konis, or like the way the back feels and then go with bilsteins, and you will then know what it's like first hand to drive with mismatched shocks, and be able to tell us all about your findings..
the fronts are a little more work than the back but doing them while they are on the car is like an easy automatic spring compressor.
Zip the top nut off with an impact, the strut mount bolts, sway bar links, and jack up the car off the springs, and lower it back down on the springs..
Myself, I don't know if I would be able to tell one shock from another as long as none are blown or extremely stiff. I'm not sure how advanced of driving skill/experience is required for feeling such small differences.
I might have a use for some front konis some time..
They are on the wishlist but the wishlist is long..
