Oil Pan Removal with Engine in Place?
gla924sem
PostPosted: Wed Nov 03, 2010 10:14 am    Post subject: Oil Pan Removal with Engine in Place? Reply with quote
Can you do it with the engine in place
Just wondering
PostPosted: Wed Nov 03, 2010 12:44 pm    Post subject: Reply with quote
Sure drop the crossmember, be carful when reinstalling it
cause you stand a chance of having it leak..just be careful its an easy do..
gla924sem
PostPosted: Wed Nov 03, 2010 6:49 pm    Post subject: 924 Reply with quote
That's not what I wanted to do.
May as well just remove the engine as it needs a rebuild anyway after losing a rod bearing.
Wanted to see which one went before doing the major removal
PostPosted: Wed Nov 03, 2010 9:46 pm    Post subject: Reply with quote
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/573276-924-oil-pan-removal.html
Rich H
PostPosted: Wed Nov 03, 2010 10:29 pm    Post subject: Reply with quote
Couple of the allen bolts are hidden by the engine mounts, but not hard.
PostPosted: Thu Nov 04, 2010 5:59 am    Post subject: Reply with quote
Driver's side mount needs to be loosened.
poor-sche
PostPosted: Sat Mar 02, 2019 4:18 pm    Post subject: Reply with quote
Is this done simply by loosening the nuts top and bottom on the rubber mount? Or do I have to also loosen the bolts holding the bracket to block? I’m guessing the latter cause I’ve loosened the 3 nuts on the rubber mount but now the mount is loose but the oil pan is still hung up on the bracket which is still rock solid in place.
PostPosted: Sun Mar 03, 2019 6:06 am    Post subject: Reply with quote
I don't get it.
I didn't mess with my engine mounts at all while replacing my oilpan gaskets.
Things to get caught up on are that high bellhousing bolt on the left side of the car and the dipstick if you forget about it.
Other than that drop the Xmember and the oilpan comes off ??
poor-sche
PostPosted: Sun Mar 03, 2019 8:01 am    Post subject: Reply with quote
The oil pan is completely loose. All the bolts are out. The pan just wiggles around but it won’t come down cause the edge is caught up against the mounting bracket. Thoroughly frustrated.
PostPosted: Sun Mar 03, 2019 8:19 am    Post subject: Reply with quote
Engine mounting to block needs to be loosened to give room to drop
poor-sche
PostPosted: Sun Mar 03, 2019 8:33 am    Post subject: Reply with quote
Figured as such. Now I have to remove the intake to get to the bolts unless there’s a secret I’m not aware of. Luckily this is not a daily driver so I can take my time.
Probably should’ve just taken the engine out.
poor-sche
PostPosted: Sun Mar 03, 2019 8:57 am    Post subject: Reply with quote
Here’s where it’s hung up, for those wondering. The lip of the pan is caught against the bend in the bracket...
PostPosted: Mon Mar 04, 2019 3:48 am    Post subject: Reply with quote
Did them all from underneath or from the front of the engine bay. Cannot remember, i might have removed the bracket from block to intake
PostPosted: Mon Mar 04, 2019 7:21 am    Post subject: Reply with quote
I guess I better check to see if my engine mount is tight in my inspection before I go to fire her back up this year. I've done the oilpan job twice.
Their are 2 bolts that attach the dipstick tube to the intake bracket with a little clamp thing. I take it off there.
poor-sche
PostPosted: Mon Mar 04, 2019 3:23 pm    Post subject: Reply with quote
I removed the bracket holding the intake to the block. I tried getting at the 3 bolts on the engine mount bracket, but there was no way to get at them. The brake booster, master cylinder, engine harness, etc. were still in the way. Had to use multiple universal joints just to get a socket on, but still couldn’t get it seated properly. I opted to just remove the intake. I honestly don’t know how to loosen them otherwise. Once loosen the pan came down with ease. What a royal pain in ass this job was.
You can see the 3 bolts I’m talking about below.
Here’s a photo of a tab on the oil pan that was keeping it from coming down.
Here’s a shot of the slot in the engine mount where the tab above sits.
