924 Misfires and stutters
Superkaiser
PostPosted: Tue Feb 19, 2019 4:56 am    Post subject: 924 Misfires and stutters Reply with quote
I’m from Germany and English is not my native language, that means you can expect some writing mistakes
I have already read a lot of threads in several forums, but haven’t found a working solution yet.
My car is 1983 Porsche 924 2.0
My problem: yesterday my engine began to stutter while accelerating. On my way home the engine shut down while I stoped at a traffic light, or rather the rev counter jumped to 0 then to 1000 and then the engine shut down. After I cranked the starter for a few seconds, the car started again and I was able the drive home, the engine was stuttering and jerking relatively strong.
At home a realized some misfires(bang from the exhaust), when I hit the gas a little bit while idling.
Until now I was able to fix all my problems with my 986 and my 924 with the help of forums in the internet...
Besides from these problems my 924 ran pretty good, I was also been driving max speed (+200km/h) several times on the Autobahn.
The spark plugs seem to be ok and have a brownish color. Also the wires look ok and they fit good on the plugs.
Is there a way to check the Hall effect sensor (idk. if that’s even the English name)?
Every help would make me happy!!
PostPosted: Tue Feb 19, 2019 6:05 am    Post subject: Reply with quote
Maybe the ignition coil is bad when heating up?
Superkaiser
PostPosted: Tue Feb 19, 2019 9:42 pm    Post subject: Reply with quote
[quote="morghen"]Maybe the ignition coil is bad when heating up?[/quote]
I also have the misfires when my engine is cold, but maybe the coil is not as good anymore. At least it looks very old.
PostPosted: Wed Feb 20, 2019 12:28 am    Post subject: Reply with quote
Welcome to the board.
If your tach is reading properly when misfiring and while accelerating, I suspect it's fuel related. Fuel filter? Fuel pump? Fuel relay?
Also check for vacuum leaks.
Superkaiser
PostPosted: Thu Feb 21, 2019 4:36 am    Post subject: Reply with quote
Thanks Paul, I’m going the replace the filter first. Any way to check the fuel Relais?
PostPosted: Thu Feb 21, 2019 5:50 am    Post subject: Reply with quote
Look up Thomas at werk924.com as he's in Germany. He is Herr 924!!
