924S Head Gasket Replacement Question
wrenchesandswearing
PostPosted: Fri Jun 23, 2017 4:31 pm    Post subject: 924S Head Gasket Replacement Question Reply with quote
I know enough to make sure to buy quality parts, and I have a complete Reinz upper engine gasket set I snagged off AutohausAZ on the cheap. My question is about gasket compound/sealer. Should I order a tube to use on my replacement or skip it? The PO obviously skipped it or the head gasket wouldn't have come out without resistance.
EDIT: After more confusing searching, I've come to the conclusion that it should be fitted dry. I know I need to find the correct torque specs, but I want to make absolutely sure I don't have to soak it or use anything special before I get it all back together.
If at first you succeed, failure is imminent.
1987 924S - A heap of a project
hdrider19
PostPosted: Fri Jun 23, 2017 7:35 pm    Post subject: Reply with quote
Here is a link to what you need.
http://www.clarks-garage.com/shop-manual/cyl-02.htm
Hope that helps.
87 924S
PostPosted: Fri Jun 23, 2017 10:27 pm    Post subject: Reply with quote
It's a very good idea to send the head in first and check for warpage before assembly. You'll end up doing this job twice if warped.
wrenchesandswearing
PostPosted: Sat Jun 24, 2017 4:23 am    Post subject: Reply with quote
hdrider, I keep Clark's open on my tablet and with me. It's been a godsend. Paired with the 944 Hayne's manual, I don't think I could fail.
I might hit you up for some parts though. I know of at least 3 things I need.
Grenadiers, I planned on taking it into a local shop. There's too much wrong with this car to assume that it's still flat.
hdrider19
PostPosted: Sat Jun 24, 2017 12:21 pm    Post subject: Reply with quote
Here is a link for a video that might help.
http://youtu.be/9eazqnUBVOE
This guy is a board member and does lots of helpful videos. Keep an eye on his channel for reassembly video.
87 924S
wrenchesandswearing
PostPosted: Sun Jun 25, 2017 12:08 am    Post subject: Reply with quote
I subscribed to edredas. His videos have been a huge help too.
Also, thanks for linking that video. I was wanting to delete the ultra leaky sunroof on mine but wasn't sure how that would look. The PO apparently felt the need to remove and discard all of the electrical and mechanical parts, the seals are shot and the roof has been dropped several times. I don't see the sense in restoring it to working order if it will cost a kidney and eventually leak in on the interior.
hdrider19
PostPosted: Sun Jun 25, 2017 12:23 pm    Post subject: Reply with quote
Here is a link where a guy is replacing the roof skin on a non sun roof car. Thought you might be interested.
http://youtu.be/Qc5Ig4-VnUE
87 924S
wrenchesandswearing
PostPosted: Mon Jun 26, 2017 3:22 pm    Post subject: Reply with quote
I knew it was a job, but that's a huge undertaking. I may have to redneck it closed for the time being while I sort the other issues out. I aim to have this car running and roadworthy by fall. At least soon enough to get the landlord and the city off my back. Unlicensed derelict blah blah blah...
PostPosted: Tue Jun 27, 2017 11:59 am    Post subject: Reply with quote
Color matched racers tape keeps the roof panel from leaking as does RTV silicone.
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Thu Jun 29, 2017 2:49 am    Post subject: Reply with quote
Sunroof is designed to "leak"...
PostPosted: Thu Jun 29, 2017 5:46 am    Post subject: Reply with quote
None of mine have ever leaked....but we don't get as much rain as Portland!
Replace both seals and keep the drains open.
