Looking for connector end
michel j
PostPosted: Thu May 12, 2016 3:56 pm    Post subject: Looking for connector end Reply with quote
Hi,
I was wondering if anyone would have the male end of the circular connector that fits the fuel temp gauge.
Thanks,
Michel
[img][/img][/url]
Michel J
"Wanting to own a 924 Turbo someday"
PostPosted: Tue May 17, 2016 3:23 am    Post subject: Reply with quote
What year is your car. I'm not 100% certain that the pinout stayed the same across the range.
Tanso
PostPosted: Thu May 19, 2016 4:56 am    Post subject: Reply with quote
That gauge is from a late car. They changed the connection from 1980.
Our 1983 Porsche 924 project: http://www.924board.org/viewtopic.php?p=364034#364034
michel j
PostPosted: Thu May 19, 2016 2:58 pm    Post subject: Reply with quote
That is a good thing to know. I will be rewiring so no matter. Still looking for connector that will fit those pins on the gauge.
Michel J
JjyKs
PostPosted: Thu May 19, 2016 7:07 pm    Post subject: Reply with quote
One way could be finding single connectors that fit those pins on the cauge and making the connector yourself.
Did one connector for my old merc that way and it works and doesn't even look that bad. Only problem is that you can't remove the wires from the connector like you could with normal connector.
Basically, find some connectors that just fit the single pins on that cauge, get something that you can drill (wood or plastic) and is tall enough to fit the connectors inside it.
Mark the cauge pins on that thing you're going to use. Drill the holes, put the connectors there and epoxy them in place.
michel j
PostPosted: Fri May 20, 2016 12:44 am    Post subject: Reply with quote
Thanks for the good suggestion. I may do that.
Michel J
PostPosted: Fri May 20, 2016 1:24 am    Post subject: Reply with quote
Before you do, let me check my bin of wire harness bits. I might have one for you.
