40DCOE's running lean video
bradelporsche
PostPosted: Thu May 08, 2014 3:47 am    Post subject: 40DCOE's running lean video Reply with quote
Did some more work on the car. Cam timing was off. Lined up both marks on crank(flywheel) and camshaft pulley and reset the distributor rotor. (the lead for cyl 1 was on cyl 4)...
Now I am thinking the Carburators are running lean. What I do find weird is that the mixture screws on cyl 1&2 carb don't do anything. While 3&4 are working as they should...
The car is using an autozone fuel pressure regulator (These should run 3.5 psi?) so no idea how much PSI is getting to them. I am thinking of using a T in the middle of the carbs rather than have it run as it does now.
Thoughts?
https://www.youtube.com/watch?v=HU1cjMw5q8Y&feature=youtu.be
Last edited by bradelporsche on Thu May 08, 2014 11:15 am; edited 2 times in total
PostPosted: Thu May 08, 2014 4:09 am    Post subject: Reply with quote
if the mixture screw does nothing I would bet that that jet path is completely clogged....
it being clogged it would act like your mixture screw was ran all the way in to a stop (lean)...
sometimes bottoming out these screws and pulling them all the way back out will dislodge the clog..
count turns in to bottom on your good one where it runs best and copy that onto your other one..
if that doesn't work run your bad screw almost all the way out to open up that path, get it running, rev it up to a few k rpm's, put your palm over the carb intake and hold the throttle butterfly wide open to induce a massive vacuum inside the carb... more rpm=more vacuum
a lot of the time hand choking carbs like that will suck any BS through the ports, you should end up with a gasoline soaked hickey on your palm...
kindof like a self cleaning oven
if that fails bring the carbs in the kitchen, strip them down to every little spring and pin, gently set the carb bodies in the sink and tell the misses she has some dishes to do while you attack the finer pieces with carb cleaner..
compressed air and fine wire are great through small jet paths..
bradelporsche
PostPosted: Thu May 08, 2014 11:01 am    Post subject: Reply with quote
Fantastic worked as described! Night and day difference! Thanks for the tip
Now the set of carbs that was fine isn't pulling as much vacuum when I choke it by hand. (must be leaking at the gasket)
I did remove and re install the 1st set to make sure it didn't have a vacuum leak. I have ordered the soft mounts. I'll install them, hand choke the second set and start driving it on the street.
Much more drivable now. After the carbs are set I will look at retrofitting a Ford EDIS system.
Then a few bit after that build a 88mm block with forged VW flat top pistons, lightweight flywheel, should net a 11:1 compression ratio.
https://www.youtube.com/watch?v=63NENp6aa1g&feature=youtu.be
PostPosted: Thu May 08, 2014 11:20 am    Post subject: Reply with quote
Msd works well with carbs.
PostPosted: Thu May 08, 2014 11:38 am    Post subject: Reply with quote
any vacuum leak between the carbs and the head will also cause a lean condition, especially at idle, cause high idle...
your getting air into your engine that the carbs don't know about basically and haven't had a chance to introduce the proper amount of fuel for that air, if the air doesn't pass the venturi, said amount of air doesn't get a fuel mixture
yes new video is much better...
go ahead and hand choke all of em just because...
maybe even shut off the fuel pump,
unplug the fuel line, let the car run until it uses all the gas in the float bowls and dies,
spray a bunch of carb cleaner into the fuel lines toward the carbs to refill the float bowls with the cleaner,
plug the line back in and get the car to start for a couple seconds to get the cleaner deep in the carbs,
shut it off as soon as it runs a bit to let the cleaner sit in the carbs for a half hour or so to sit and dissolve the BS,
and then just run it for a while until it eats all the cleaner up and your back to straight gas...
it will run on carb cleaner, maybe not excellently though until its all gone
love your carbs btw
bradelporsche
PostPosted: Thu May 08, 2014 2:12 pm    Post subject: Reply with quote
I will give that a try.
Any tips on how to and where to hook up the vacuum advance and retard for the distributor?
I am assuming the source for retard can be taken anywhere post carburators. The advance will need to be before the venturi... Is that what those white caps are for?
PostPosted: Thu May 08, 2014 3:27 pm    Post subject: Reply with quote
I know carbs but im pretty new to the 924 or any Porsche for that matter...
I was able to dig this little tidbit out for ya though...
Paul wrote:
Users of Weber carbs almost always converted to mechanical advances and ran the carbs rich to help avoid pinging under load.
http://www.924board.org/viewtopic.php?p=40076&sid=3627dbc9a50eb67e9eea7c51dc786395
http://www.924board.org/viewtopic.php?p=82874&sid=08c8aa9914e2f90ef3e3a8da6d6ffd49
google search = site:924board.org carbs distributor advance
not to dog this great sight but the insight search is trash if you ask me
bradelporsche
PostPosted: Fri May 09, 2014 12:06 am    Post subject: Reply with quote
Thanks for the info.
My car being a 77' with the 77 distributor is a plus. I'll set initial timing at 2 degrees BTDC.
Endwrench recommended hookup the vacuum advance to manifold vacuum for an extra 4-10 degrees of advance when cruising.
Ideally I will just convert it to full EDIS ignition and not deal with weights, springs or vacuum timing.
Also found the generic fuel pressure regulator that was used
http://www.oreillyauto.com/site/c/detail/MRG0/9710/N0514.oap?ck=Search_N0514_-1_-1&pt=N0514&ppt=C0128
Looks like the numbers on the dial are 1:1. I'll run the car on the 3.5 setting as I have been running it on 6 per previous owner recommendations
PostPosted: Fri May 09, 2014 12:20 am    Post subject: Reply with quote
Dizzy advance should not go to manifold vacuum.
The only way to do this right is to send your dizzy in to be recurved. There is a place here in town that does it quite reasonably: Philbin.
PostPosted: Fri May 09, 2014 12:28 am    Post subject: Reply with quote
Sounds 10x better.
bradelporsche
PostPosted: Fri May 09, 2014 12:45 am    Post subject: Reply with quote
Thanks for the link.
I agree but want to make it a little more drivable on the street with better economy.
I'll advance my cam timing by 2 degrees and set initial timing to 0-3 degrees BTDC.
I have a spare 78+ distributor that I can go ahead and send out to have it recurved!
I'm thinking
22° at 2750 rpm.
26° by 3250.
will suit me well. with an initial advance of 3-8 btdc to play with.
PostPosted: Fri May 09, 2014 2:02 am    Post subject: Reply with quote
More like 35 degrees of total advance.
PostPosted: Fri May 09, 2014 3:26 am    Post subject: Reply with quote
26, 35, whatever it takes. LOL
bradelporsche
PostPosted: Fri May 09, 2014 4:25 am    Post subject: Reply with quote
Yes,
I'm actually just going to skip recurving the dizzy and go with an EDIS-4 solution.
Got lucky at a local salvage yard. Now just buy Ideolas trigger wheel and a trip to the hardware store for anything I can use to rig up a sensor mount.
After it's all setup getting a megajolt JR.
bradelporsche
PostPosted: Fri May 16, 2014 1:50 am    Post subject: Reply with quote
It looks like I may need a new spill jet.
The old ones are inconsistent and filled with muck causing the ball inside to move at inconsistent rates.
