Posted: Fri Oct 18, 2013 4:26 am Post subject: Firewall Blues |
Posted: Fri Oct 18, 2013 4:51 am Post subject: |
jazz guy
Posted: Fri Oct 18, 2013 5:27 am Post subject: |
Ouch, sorry  |
Posted: Fri Oct 18, 2013 5:43 am Post subject: |
owie !
reinforcement plate? _________________ Supercharger and EFI kits
https://www.the924.com |
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Fri Oct 18, 2013 7:09 am Post subject: |
Duct tape or hot wrench.... you decide. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Fri Oct 18, 2013 7:12 am Post subject: |
Not sure what the fix will be, but I'll post whatever I decide.
The reinforcement plate is tempting, but the problem is the firewall is not flat in that area, particularly where the clutch master bolts up. . .it is shaped to orient the cylinder parallel to the pedal travel, and a flat piece there apparently causes excessive wear on the cylinder due to misalignment.
!tom
Posted: Fri Oct 18, 2013 3:05 pm Post subject: |
Can't you just weld it back up? _________________ 78 924 NA
5-lug |
Posted: Fri Oct 18, 2013 3:37 pm Post subject: |
Welding is the last option on these cars.
My car was a NA and the place where the clutch cyl is was flat...so i added a thick aluminium plate.
I did notice the missalignment but that could be corrected with a custom bit of steel...no big deal. _________________ Supercharger and EFI kits
Posted: Fri Nov 01, 2013 6:58 am Post subject: |
Curiosity got the best of me, in time! Mine is doing the same thing. Of course I had the black plastic firewall stuff in place, didn't see this before. This car of mine is jinxed, this is just the latest. Grrrrrr..
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Fri Nov 01, 2013 7:35 am Post subject: |
Getting a repair plate from Rennbay. . .stand by for installation pics. _________________ Toofah King Bad
!tom
Posted: Fri Nov 01, 2013 2:29 pm Post subject: |
| morghen wrote: | | Welding is the last option on these cars. |
Why?
I've welded up a few cracks.
Please enlighten me as to why this was a bad idea. _________________ 78 924 NA
5-lug |
Posted: Sat Nov 02, 2013 4:41 am Post subject: |
Very thin metal there. Strengthening a crack by laying a bead over it will cause neighboring areas to fail. Also finding the end of a crack can be problematic. _________________ Toofah King Bad
Posted: Sat Nov 02, 2013 5:08 am Post subject: |
| !tom wrote: | | morghen wrote: | | Welding is the last option on these cars. |
Why?
Please enlighten me as to why this was a bad idea. |
What Rasta said + the heat from the weld destroys the galvanic coating around the area where you weld...making easyer for rust to begin eating your car. _________________ Supercharger and EFI kits
Posted: Wed Nov 06, 2013 2:14 pm Post subject: |
Well, I made a 22 gauge sheet metal patch and riveted it using ten 3/8ths inch steel rivets. Worked out great, no deflection so far. Noticeable pedal improvement. _________________ '83 944 Track car.
Posted: Sat Nov 16, 2013 2:56 am Post subject: |
Repair underway:
