Help with fuel relay
kylekev
PostPosted: Fri Aug 23, 2013 10:05 pm    Post subject: Help with fuel relay Reply with quote
Hi all,
This week i've been looking for a new fuel relay for my 78 924 and haven't had any luck finding it. So the question is, does anyone know where I can get one. Tried places like Pelican parts, autoalanta, and a few other Porsche sites but still nothing.
number on relay # 477-906-059
note: The relay does have a Fuse on top of it, in case the fuse burns out.
Thanks everyone:)
Ozzie
PostPosted: Sat Aug 24, 2013 12:11 am    Post subject: Reply with quote
hard to find new, if at all.
I have one but you might get one closer to you.
Its AUTO and its BLACK
Montego Black on black/red
scm924s
PostPosted: Sat Aug 24, 2013 6:33 am    Post subject: Reply with quote
These are NLA, I bought mine in the USA! They need the fuse because the fuel pump circuit on early cars doesn't have a fuse on the fuseboard.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
kcoyle
PostPosted: Sat Aug 24, 2013 7:56 am    Post subject: Reply with quote
Not sure if a 1979 is the same but I got a few parts from these guys. Very nice to deal with.
http://hudsonvalley.craigslist.org/cto/3939020385.html
1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
ThomasJoseph315
Guest
PostPosted: Sat Aug 24, 2013 9:43 am    Post subject: Reply with quote
I herd a rumor you can take a 1980 relay, crack it open and wire in a inline fuse
scm924s
PostPosted: Sat Aug 24, 2013 4:06 pm    Post subject: Reply with quote
I think there is a bit more to it than that, but I am no electrician. The early relays are 6 pin, the later ones 5 pin. I think you have to modify the wiring such that the fuel pump no longer operates from the switch on the air flow intake flap, but from the switched ignition live, but on the face of it that means the pump will continuously run if the ignition is on, not a good thing in a crash!
Needs someone with a bit more knowledge than me! Don't forget though that an in line fuse is necessary as there is no fuel pump circuit fuse on these early cars, other than the one on the relay.
Be good to know if there is a viable alternative in the event these relays are unobtainable.
1977 Martini - sold
kylekev
PostPosted: Mon Aug 26, 2013 10:24 am    Post subject: so next question Reply with quote
So i get power to my fuel pump but im not getting power to my cold start stuff. AKA cold start valve, thermo time switch, aux air valve and something else I think.
The idea was to just buy a new fuel pump relay and see if that fixed those problems. I thought i read somewhere that all these where powered by the fuel pump relay.
Any idea's?
I will also check wire diagram tonight.
Thanks everyone, big help
kylekev
PostPosted: Mon Aug 26, 2013 12:36 pm    Post subject: ugh Reply with quote
Yep all of those are connected to the fuel pump relay.
ThomasJoseph315
Guest
PostPosted: Tue Aug 27, 2013 3:38 am    Post subject: Reply with quote
If fuel pump shut off is what your worried about, you could put in a secondary relay connected to the alternator, if the alternator stops the fuel will be cut. On starting, when the alternator is generating power would flip the switch. Tho you may have to put in some kinda timer with some minor circuitry.
Also, be advised,.. I don't think there is rollover valves in these cars anyway. Hell they don't even have lap belts, lol.
PostPosted: Tue Aug 27, 2013 3:47 am    Post subject: Reply with quote
If the fuel pump is running, but the other items are not, then I don't think it is the fuel pump relay, but perhaps the relay panel itself or the power and ground connections for those items.
Check the grounds under the dash, behind the relay/fuse panel and the connections under the hood (specifically the ground points). Worst case, the relay/fuse panel itself could be corroded internally, which is a bit of a pain to deal with, but if you're careful you can get it out and clean it up.
Good luck,
