Best source for replacement starter & alternator?(GM Alt
PostPosted: Mon Aug 19, 2013 3:01 am    Post subject: Best source for replacement starter & alternator?(GM Alt Reply with quote
The starter has 'stuck brushes' and the alternator failed the Stator test.
Where would be the best place to get replacement units?
I believe that some folks have used a GM alternator to replace the Bosch unit.
How feasible is this to do?
Is there a GM Alternator (Part# ???) that is a direct bolt in replacement or one that only meeds a minimum of adaptation?
At http://www.924.org/techsection/11electrics.htm I see-->
"david.c.russell@lmco.com
I have seen a few posts about using a Delco Alternator on the 924, and thought I would share my experience with using one on my 1980 931. I switched to the Delco about 1989 and have had no problems whatsoever since. To make the switch, I just removed the old aluminum lower bracket from the block and fashioned one of similar shape to fit the Delco from a piece of flatiron that I bought at Home Depot. I drilled the bracket to match the two original bolt holes, and used the original bolts. I did not use any rubber donuts. For the upper bracket, I bought a chrome universal alternator bracket from JC Whitney. It is shaped somewhat like a banana. To make it work, you need to cut it with a hacksaw and either weld it or bolt it back together at a slightly different angle than original. I just overlapped the two halves and drilled and bolted it back together, to get the angle I wanted. Once again, I used the original mounting bolts. The alternator I used fits a 1986 Camaro, 2.8 V6, with air. I bought it at a local Checker auto parts for $49.95, and it has a lifetime warranty. You will also need the plug for the alternator. It is available at most auto parts stores for a couple of dollars. Wire the red wire from the plug to the battery connection on the alternator (with the original battery connection). Splice the brown wire on the plug to the blue wire that went to your old alternator. Leave the Delco pulley intact, and use your original alternator belt. Works fine, lasts a long time. I have pictures if someone will tell me how to post them. Thanks, Dave."
Has anyone performed this transplant?
Also, the rubber bushings are disintegrated - I read somethong about hard plastic replacement parts from Toyota???
Does anyone have the Part # or a souce for these?
Thanks in advance...
kcoyle
PostPosted: Mon Aug 19, 2013 8:35 am    Post subject: Reply with quote
I had both my starter and alternator rebuilt by a local shop although it was way more than 49.95, it was more like $125 each but they came out like new and I know it was done well.
The bushings you can get from Dan at Ideolas garage.
http://garage.ideola.com/prod-ElectricsUpgrades.html
1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
PostPosted: Mon Aug 19, 2013 9:23 am    Post subject: Reply with quote
I bought new brushes for mine. Quick fix, other than R&R'ing the alternator.
I replaced my starter with one from an Audi 4000/5000. Smaller and slightly better than stock. There's a thread on it around here someplace.
PostPosted: Mon Aug 19, 2013 9:49 am    Post subject: Reply with quote
Hmm, wonder if that explains the mystery starter I have. . .
1980-924
PostPosted: Mon Aug 19, 2013 10:48 am    Post subject: The Audi starter is the Bosch-SR10X? Reply with quote
Is this the one you're talking about?
http://www.amazon.com/Bosch-SR10X-Starter/dp/B000BZJRSA/ref=au_as_r?ie=UTF8&Make=Porsche%7C2&Model=924%7C13&Year=1980%7C1980&carId=002&n=15684181&newCar=1&s=automotive&vehicleType=automotive
This says that it will fit a 1990 Audi 100 with the 2.3L engine, but Amazon says it will NOT fit the 924.
I like the idea that it is smaller, lighter and that it spins up with a higher RPM.
To get the starter out, I ended up cutting off the bolts to the Catalytic Converter and taking the exhaust pipe off along with removing all the heat shields - P.I.T.A.!!!
And then I had to remove the oil filter to get the starter off...
What about the GM Alternator?
Anyone using one of those?
Does it have an internal fan - eliminating the need for the intake/scoop and air hose and cap on the stock alternator?
And wouldn't that stock set up with the cap on the back of the Alternator cause it to be even hotter in traffis where there is no air being forced into the hose to reach the Alternator?
PostPosted: Mon Aug 19, 2013 1:47 pm    Post subject: Reply with quote
Probably not. Yours is a reverse rotation unit compared to mine. Though, there was a version available that was proper for the 931.
1980-924
PostPosted: Tue Aug 20, 2013 12:39 am    Post subject: Source for Alternator Bushings Reply with quote
I found that AutoAtlanta has the rubber Alternator bushings (#18 in the pic below) for $1.48 -
http://www.autoatlanta.com/porsche-parts/924-80-85/902-05.php?pn=059903263A#a
Part # 059903263A - Looks like -
I'd like to get the more durable hard plastic piece, is there a source for the polyurethane version?
I believe I saw where someone used a bushing from a skateboard and that it worked well for them.
Does anyone have the ID, OD, length on the rubber bushing?
Mine are disintegrated so I can't get the dimensions from the old ones.
PostPosted: Tue Aug 20, 2013 1:07 am    Post subject: Reply with quote
This page has the high output alternators, the gear reduction starters, OEM alternatives for both, as well as replacement bushing kits for both the 931 and NA alternator setups.
1980-924
PostPosted: Tue Aug 20, 2013 1:30 am    Post subject: Thanks for the link ideola... Reply with quote
Hi ideola,
Did I read where there were problems installing the IMI-155CW Starter and they had to grind/machine it to get the starter to fit?
I am very intertested in the SR10X Starter but I'd like to get verification that it will work.
Most electrical parts are not returnable, so I'd like to hear that it will work before I buy one.
Is the 'Quality Power 150A Alternator' a direct bolt in replacement?
PostPosted: Tue Aug 20, 2013 1:41 am    Post subject: Re: Thanks for the link ideola... Reply with quote
1980-924 wrote:
Hi ideola,
I've only had one report of that being an issue on the NAs, and that was a RHD vehicle. I can have the starter drilled for add'l indexation.
Yes and yes. The only thing required is to make a sleeved bushing from a short length of copper tube, which you can get for a few dollars. This is because the ears on the QP unit accommodate M10 bolts. The "locally made" bushing will allow you to use the OEM M8 bolts with no other modifications.
PostPosted: Tue Aug 20, 2013 2:38 am    Post subject: Re: Source for Alternator Bushings Reply with quote
Hopefully you'll have better luck with them than others have. Google Auto Atlanta here and elsewhere and decide for yourself.
PostPosted: Tue Aug 20, 2013 3:21 am    Post subject: Reply with quote
Alternator bushing kits: http://garage.ideola.com/prod-ElectricsUpgrades.html#ABK
!tom
PostPosted: Sun Aug 25, 2013 4:12 am    Post subject: Re: The Audi starter is the Bosch-SR10X? Reply with quote
I don't believe an internal fan will allow the alternator a cold air source.
See this link for a brief discussion.
78 924 NA
5-lug
PostPosted: Mon Aug 26, 2013 8:31 pm    Post subject: Reply with quote
I've installed the high torque motor from ideola in my rhd motor with no issues it grinding needed at all, works beautifully !
1979 NA
my Porsches Arse!!!
PostPosted: Tue Aug 27, 2013 4:52 am    Post subject: Reply with quote
. . .and I put one on my 2.5 race car. Spins right over off a tiny little motorsickle battery.
