Posted: Sat Nov 10, 2012 9:06 am Post subject: 'It's Alive, Part II' |
With Flosho's help, and some dumb luck, have been able to drive the CGT clone car down the road with some attitude~! If one wants to put up an EFI sticky on what not to do on a MS conversion, I have a few pointers~!
To sum up those pointers, take care of idle, just like the megamanual says, then ignition, and then fuel; not necessarily in that order. The latter, requires knowing your injectors, which I did not, then setting fuel pressure, and req_fuel. In my case, I ran it too long without that info, and the O2 sensor became useless with crud, as well as the spark plugs.
Now that the sparkys are clean, the LC-1 was re calibrated; it actually works and contributes to AFR, the fuel pressure is 59psi (have 2003 SRT4 44.5 Lb/hr injectors), the Req_fuel is set, the car works. Nice. I also was off a tooth or two on the timing belt, the crank pulley mark is almost indistinguishable. I still have working valves! All that done, I now like the car. Again~!
The car handles incredibly well, the delrin bushings squeak like a banshee, without an interior, lots of cool engine noises with the open air filter. Have to figure out how to get the brake lights to work with Painless system, before I can drive it more. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Min
Posted: Sat Nov 10, 2012 9:37 am Post subject: |
First time is always the hardest. Glad you have managed to make things work. Also happy that flosho is paying it forward.
Posted: Sat Nov 10, 2012 10:01 am Post subject: |
THanks, Jason has been a great sounding board, I owe him a few pizzas and beer this next summer! Will try to get him and Paul over at the same time!
The car was dead in the water yesterday, no start-which it did quite well, no spark, ugh. Was ready to give up. But, the no-spark intriqued me, as to, why it just happened. So, that produced inspections of the bad timing, injector info, etc. _________________ '83 944 Track car.
Posted: Sat Nov 10, 2012 12:34 pm Post subject: |
I'm happy that Dave has been able to get things figured out so quickly. The best part is still to come with more road tuning and datalogging. It's addictive. _________________ [This Space For Rent] |
Posted: Tue Nov 13, 2012 9:29 am Post subject: |
Been waiting out rain/snow down here and really cool temps before I fire up the CGT clone again. However, figured out brake lights, using a GM switch, and turn signals (two position toggle switch on dash), now on to wiper control, and electrical is done! _________________ '83 944 Track car.
