dubrict
Joined: 22 Apr 2011 Posts: 150 Location: Horseheads NY
Posted: Fri Oct 07, 2011 2:30 am Post subject: New question |
How do you turn on the light in the engine bay? _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
!tom
Posted: Fri Oct 07, 2011 2:30 am Post subject: |
With the engine out, you won't have vacuum assist, which means your pedal will be harder to press than with the engine running.
You've got another issue with your brakes. The E-brake is in absolutely no way related to engine, and the assist to the service brakes is unavailable when the engine isn't running.
Perhaps the master cylinder or brake lines were affected when pulling your motor. Either that, or the seals have dried up and you need a rebuild.
What electrical components do you want to test? _________________ 78 924 NA
5-lug |
StienbargerR
Posted: Fri Oct 07, 2011 3:59 am Post subject: |
Thanks guys. Im guessing the rear drum seals have dried up. They didnt look too good. There was alot of gunk in there which Im thinking is brake fluid that collected brake dust.
As for electrical, I just want to verify that everything is working. I had a pretty bad back feed when my started wires got crossed, and there was some light smoke coming from under the dash and near the fuel pump _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
Posted: Fri Oct 07, 2011 4:34 am Post subject: |
Gunk in brake lines is usually the rubber seals and lines breaking down. Not good.
Make sure the drums are properly adjusted as well. They don't automatically adjust and can cause low pedal, etc. _________________ Stefan
Ozzie
Posted: Fri Oct 07, 2011 7:37 am Post subject: Re: New question |
| dubrict wrote: | | How do you turn on the light in the engine bay? |
Lights need to be on and there is a tilt switch in the light fitting. (unless replaced) _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
dubrict
Posted: Fri Oct 07, 2011 12:40 pm Post subject: Re: New question |
| Ozzie wrote: | | dubrict wrote: | | How do you turn on the light in the engine bay? |
Lights need to be on and there is a tilt switch in the light fitting. (unless replaced) |
Must be a faulty tilt switch then... _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
Posted: Fri Oct 07, 2011 1:22 pm Post subject: |
My 944 radiator has a 3 prong thermoswitch on it.. Anyone know which prong is for thermofan , ac, lighting up my Xmas tree etc? _________________ 1979 NA
my Porsches Arse!!! |
StienbargerR
Posted: Sat Jun 09, 2012 8:02 am Post subject: |
I just got a victor reinz gasket set for the bottom end. I have 3 pieces left over from it.-
-A brass washer
-2 Clear plastic tube things that look like they are heat shrink
Where do they go?
Thanks in advance. _________________ 1978 924 NA
Harm
Posted: Sun Jun 10, 2012 2:13 am Post subject: Re: Stupid 924 question amnesty |
| StienbargerR wrote: | -A brass washer
-2 Clear plastic tube things that look like they are heat shrink |
Maybe these where usefull on the LT/100 that used the same engine's bottom end?
or belong to the 931/CGT?
I've got a Goetze set on the shelf that shows the brass ring,
but I don't recognize the two clear plastic tube things in there.
HTH
Regards, Harm. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Sun Jun 10, 2012 3:03 am Post subject: |
| StienbargerR wrote: | I just got a victor reinz gasket set for the bottom end. I have 3 pieces left over from it.-
-A brass washer
Where do they go?
Thanks in advance. |
Oil drain plug washer? _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
old 924
Joined: 06 Mar 2012 Posts: 184 Location: clinton twp MI. USA
Posted: Sun Jun 10, 2012 7:19 am Post subject: Re: New question |
| dubrict wrote: | | How do you turn on the light in the engine bay? | i dont feel so bad asking this the other day now...lol _________________ base 77 924 2.0 (may the porsche be with you) |
Harm
Posted: Sun Jun 10, 2012 10:41 pm Post subject: Re: Stupid 924 question amnesty |
| 924-76 wrote: | | StienbargerR wrote: |
-A brass washer
-2
Oil drain plug washer? |
It does fit the drain plug.
!tom
Posted: Mon Jun 11, 2012 12:56 am Post subject: |
Might those be used to put over the end of something that is threaded to protect something else?
For example, put them over the rod bolts to protect the crank during reassembly, or put them over something else to protect a gasket from tearing.
I have no idea how big they are, so these are only guesses. _________________ 78 924 NA
5-lug |
Luvmy80-924
Posted: Mon Jun 11, 2012 5:20 am Post subject: |
1980 moon roof ( I dont have an owners manual) what is the strap that buttons to the roof for. Is that roof strictly in or out or can you prop it open somehow without loseing the roof? _________________ 1980 924 N/A Everyday Driver
1986 930
And now a 1980 931 |
StienbargerR
Posted: Mon Jun 11, 2012 5:28 am Post subject: |
I could be wrong as I don't have a '80 model, but i think the straps are there so the roof doesn't blow off if you decide to prop the back open. _________________ 1978 924 NA
