Euro924S2
Posted: Mon Oct 10, 2011 7:04 am Post subject: What wheel offset and spacer fills the 931 standard wings? |
Hi guys. I've read the wheel thread but very few of the posts include offsets etc.
Basically I just need to know what is the maximum ET and spacer combination will still allow the wheels to fit under the front standard 931 fenders/wings. Does anyone know???
I have a set of ET 32 17"x7J alloys but they have the wrong stud pattern so I need to use 15mm spacers.
Cheers, John. _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
Posted: Mon Oct 10, 2011 4:18 pm Post subject: |
It also depends a lot on what wheel alignment you have, so comparing is not always so easy. you will probably run into problems with those wheels, my cookie cutters are ET23 and 7" wide, with almost -3 degrees camber it woorks out pretty good. But standard camber and wheels even wider out can be a big problem up front, rear aswell. _________________ 1980 924 Turbo
