jamis1970
Joined: 08 Oct 2010 Posts: 56 Location: big bear lake 92315
Posted: Fri Sep 23, 2011 11:17 am Post subject: Cheap easy fix for heater fan blues.... |
On a whim I decided to check out my gutless heater fan. It usually only blows weak. I ran some test leads direct from heater fan to battery. She was blowing like a jet engine. I then bought a 2.00 toggle switch and mounted it on my lower guage panel and ran new wires from battery to toggle swith to fan and ran new ground from fan to battery neg. Now in the chilly morning i start my car flip my toggle switch and presto... high volume air from my heater fan. I mean jet wash... lol. Can any of you enlighten me if this is dangerous to do? It seems to work excellent. Its only been installed a few days but its been incredible. _________________ 1979 924 N/A Not Fast, but a BLAST to drive. |
stevekat
Posted: Fri Sep 23, 2011 11:45 am Post subject: |
Keep a fire extinguisher handy, and make sure to fuse the circuit. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
jamis1970
Posted: Fri Sep 23, 2011 12:00 pm Post subject: heater fan |
Ive got one of those inline fuses on it now. Any idea of how many amp fuse i should use 5, 10, 15, 25, ect. Your fire extingusher comment is making me sweat. Discuss. _________________ 1979 924 N/A Not Fast, but a BLAST to drive. |
stevekat
Posted: Fri Sep 23, 2011 12:45 pm Post subject: |
Being semi-facetious with the fire extinguisher suggestion.
If you are fused you are probably OK. Not sure what rating fuse. Others may be able to chime in on that. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Ozzie
Posted: Fri Sep 23, 2011 9:19 pm Post subject: |
Your probably going to run too cold.
Normal operation- Fan runs fast when motor running and is hot.
After shut down the fan runs at slow speed until the thermo switch cuts out.
There is a resistor in the circuit that is bypassed by the relay to run the fan at full speed. Sounds like a fault in the wiring, relay, resistor or thermo switch.
16A fuse _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Sat Sep 24, 2011 2:38 am Post subject: |
He's talking about his in-cab heater system. I did the same thing on Spike, but ran it thru a relay, much safer than just using a switch. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Sat Sep 24, 2011 3:21 am Post subject: |
| Grenadiers wrote: | | I did the same thing on Spike, but ran it thru a relay, much safer than just using a switch. |
Hmm, then why not use the juice from the #3 (high) position on the fan switch to trigger the relay? _________________ Toofah King Bad
stevekat
Posted: Sat Sep 24, 2011 4:35 am Post subject: |
Good idea. But isn't the heater fan control on the 1981 and earlier actually a flat rheostat? I think the 1982 got a multi-position switch. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Posted: Sat Sep 24, 2011 6:42 am Post subject: |
Uh, there was still a 'few' wires to sort out, even though all the heater control wires were attached. I might have missed one. _________________ '83 944 Track car.
Ozzie
Posted: Sat Sep 24, 2011 8:09 am Post subject: |
| Grenadiers wrote: | | He's talking about his in-cab heater system. I did the same thing on Spike, but ran it thru a relay, much safer than just using a switch. |
my bad _________________ Porsche 924 1984 (UK import) NA
Posted: Sat Sep 24, 2011 8:23 am Post subject: |
| stevekat wrote: | | Good idea. But isn't the heater fan control on the 1981 and earlier actually a flat rheostat? I think the 1982 got a multi-position switch. |
Nope, looks like one put there is no potentiometer. . .just three outputs. _________________ Toofah King Bad
