Cheap easy fix for heater fan blues....
jamis1970
PostPosted: Fri Sep 23, 2011 11:17 am    Post subject: Cheap easy fix for heater fan blues.... Reply with quote
On a whim I decided to check out my gutless heater fan. It usually only blows weak. I ran some test leads direct from heater fan to battery. She was blowing like a jet engine. I then bought a 2.00 toggle switch and mounted it on my lower guage panel and ran new wires from battery to toggle swith to fan and ran new ground from fan to battery neg. Now in the chilly morning i start my car flip my toggle switch and presto... high volume air from my heater fan. I mean jet wash... lol. Can any of you enlighten me if this is dangerous to do? It seems to work excellent. Its only been installed a few days but its been incredible.
1979 924 N/A Not Fast, but a BLAST to drive.
stevekat
PostPosted: Fri Sep 23, 2011 11:45 am    Post subject: Reply with quote
Keep a fire extinguisher handy, and make sure to fuse the circuit.
jamis1970
PostPosted: Fri Sep 23, 2011 12:00 pm    Post subject: heater fan Reply with quote
Ive got one of those inline fuses on it now. Any idea of how many amp fuse i should use 5, 10, 15, 25, ect. Your fire extingusher comment is making me sweat. Discuss.
stevekat
PostPosted: Fri Sep 23, 2011 12:45 pm    Post subject: Reply with quote
Being semi-facetious with the fire extinguisher suggestion.
If you are fused you are probably OK. Not sure what rating fuse. Others may be able to chime in on that.
Ozzie
PostPosted: Fri Sep 23, 2011 9:19 pm    Post subject: Reply with quote
Your probably going to run too cold.
Normal operation- Fan runs fast when motor running and is hot.
After shut down the fan runs at slow speed until the thermo switch cuts out.
There is a resistor in the circuit that is bypassed by the relay to run the fan at full speed. Sounds like a fault in the wiring, relay, resistor or thermo switch.
16A fuse
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Sat Sep 24, 2011 2:38 am    Post subject: Reply with quote
He's talking about his in-cab heater system. I did the same thing on Spike, but ran it thru a relay, much safer than just using a switch.
PostPosted: Sat Sep 24, 2011 3:21 am    Post subject: Reply with quote
Hmm, then why not use the juice from the #3 (high) position on the fan switch to trigger the relay?
stevekat
PostPosted: Sat Sep 24, 2011 4:35 am    Post subject: Reply with quote
Good idea. But isn't the heater fan control on the 1981 and earlier actually a flat rheostat? I think the 1982 got a multi-position switch.
PostPosted: Sat Sep 24, 2011 6:42 am    Post subject: Reply with quote
Uh, there was still a 'few' wires to sort out, even though all the heater control wires were attached. I might have missed one.
Ozzie
PostPosted: Sat Sep 24, 2011 8:09 am    Post subject: Reply with quote
my bad
PostPosted: Sat Sep 24, 2011 8:23 am    Post subject: Reply with quote
Nope, looks like one put there is no potentiometer. . .just three outputs.
