Power window removal
dubrict
PostPosted: Fri Jun 10, 2011 8:49 am    Post subject: Power window removal Reply with quote
Trying to remove power windows from a parts car today. Can't cut a big hole in the inner door panel. Is there a simple way to take apart the power window unit and get it out, or do I have to win a fiddling contest with satan to make this happen?
mikebola
PostPosted: Fri Jun 10, 2011 10:21 pm    Post subject: Reply with quote
I ended up disassembling the whole door to get my first one out, but the second one came out when I just removed the screws from the regulator and slid it to he side. one of the arms is on a pivot, so you can rotate once you get it out of the track.
The window was up when I did mine, and I had a hand holding the glass up (but you can probably get away with a decent amount of duct tape)
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
PostPosted: Fri Jun 10, 2011 10:31 pm    Post subject: Reply with quote
I just removed two, only took a few minutes on each door. The upper left door slot is where you feed the window arms thru, and the motor follows.
dubrict
PostPosted: Sun Jun 12, 2011 2:04 am    Post subject: Reply with quote
I've tried this at every angle but no luck. Maybe I'm just being too ginger with it. One of these days they'll design a car where the inner door panel can be unbolted, wouldn't that be a dream?
1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota
PostPosted: Sun Jun 12, 2011 2:53 am    Post subject: Reply with quote
No, my windows were up, not sure if that makes a difference. After removing the screws holding the mech. to the door, the window can be removed. There after, the scissor arms are put together, and then fed thru the opening.
dubrict
PostPosted: Sun Jun 12, 2011 5:22 am    Post subject: Reply with quote
window's already out, guess I'll just keep trying today if I have time
1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota
dubrict
PostPosted: Sun Aug 07, 2011 1:52 pm    Post subject: Reply with quote
Just started tearing apart an '81 931, and now I know why power windows were so much easier to remove for some people than others. The entire unit in the 931 is MUCH smaller than the '79 924
1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota
v8carreragts
PostPosted: Thu Aug 11, 2011 1:25 pm    Post subject: Reply with quote
That's odd. I have a drivers side power window regulator to put in my 84 944 and it is the same (mirror image) of the 944 passenger side. The early motor is slightly different though. I never had any problems getting these out of any year.
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze
