under hood light
jamis1970
PostPosted: Tue Mar 15, 2011 8:08 am    Post subject: under hood light Reply with quote
Yep tried the search but thats futile. Can we make the search function search just the topic title? Anyway, Is there a switch or something for the under hood light? Ive got a new bulb in it but I cant figure out how to turn it on. Mine only has one wire going to it.
1979 924 N/A Not Fast, but a BLAST to drive.
PostPosted: Tue Mar 15, 2011 8:11 am    Post subject: Reply with quote
It is an integral mercury-activated switch. When the hood is up, theoretically the mercury closes the circuit and the light should light up. Assuming (A): you have good ground; and (B): the mercury is still in the switch; and (C): the bulb holder isn't corroded to heck or otherwise non-functioning; and (D): the rest of the circuit is functioning properly. Also, IIRC, by default is wired to only come on when the parking lamps or head lamps are illuminated.
PostPosted: Tue Mar 15, 2011 8:15 am    Post subject: Reply with quote
Related reading: http://www.924board.org/viewtopic.php?p=67372&highlight=mercury+switch#67372
jamis1970
PostPosted: Tue Mar 15, 2011 8:42 am    Post subject: hood light Reply with quote
Thanks for the great info. I will clean the area in and out for the ground im thinking now the mercury switch is broke. What would i do without you guys. When I search keywords why do i always wind up with 100 topics that dont apply to my search query?
PostPosted: Tue Mar 15, 2011 8:46 am    Post subject: Reply with quote
Try doing a search using the "search for all terms" options. Sometimes, it also helps to set the "Display results as:" to "posts" rather than "topics". If that fails, Google's advanced search can also be used by setting the "Search within a site or domain:" field to http://www.924board.org
jamis1970
PostPosted: Tue Mar 15, 2011 8:49 am    Post subject: hood light Reply with quote
re sanded contacts and inside bulb housing, fired her up hit the parking light switch and..... wait for it.......wait forrr it......... LIGHT!!! YES!!!!
PostPosted: Tue Mar 15, 2011 9:26 am    Post subject: Reply with quote
