Brendan
Posted: Wed Jan 26, 2011 9:54 am Post subject: 77 1/2 |
I keep hearing about the '77 1/2 924 model year. I just bought a '77 (or maybe a '77 1/2?)
Should I care? Was there a design change mid year? |
Khal
Posted: Wed Jan 26, 2011 10:32 am Post subject: Re: 77 1/2 |
| Brendan wrote: | | ...the '77 1/2 924 model year... Was there a design change mid year? |
Yep. More than one, I think. IIRC, at the very least, they added a sway bar to the rear? I think they raised the power, too, with higher compression and maybe a some other mod's.
The engine codes changed from XH, XF to XG, XE and the transmission codes changed from 088/6 to 088/A, apparently. Although what that means is beyond me. If I had to guess, I'd say the engine codes changed because of the above-mentioned compression increase and the transmission codes might've changed because of a change in ratios or the addition of an automatic?
| Brendan wrote: | | Should I care? |
Nah. Before they got five-speeds and a turbocharger, they were all equally awful ( ) _________________ '80 924 Turbo |
Captain_Kirk
Posted: Wed Jan 26, 2011 11:25 am Post subject: |
What's the best way to tell if 77 1/2? Mine has a rear sway. Any way to check by vin or is it a certain build date? Like if it's a (i.e. 10/76 and later, it's a 77 & 1/2)? _________________ 1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body |
Posted: Thu Jan 27, 2011 1:04 am Post subject: |
Check the engine code.
The 77.5 engine was much better, more powerful, in a number of ways.
Of course, you might even find the answer if you read the FAQ!  _________________ Vaughan Scott
Brendan
Posted: Thu Jan 27, 2011 8:43 am Post subject: |
I looked and don't see anything regarding this question. If it's in there, I'd love a link.
Thanks,
Brendan |
Captain_Kirk
Posted: Thu Jan 27, 2011 10:32 am Post subject: |
Click on the blue worded line in Khals post that says
"The engine codes changed from XH, XF to XG, XE and the transmission codes changed from 088/6 to 088/A, apparently.
Print it then take out to your car and find engine code.
Cant wait till I get home and see if two little letters give my '24 fifteen more horseys. _________________ 1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body |
Khal
Posted: Thu Jan 27, 2011 10:40 am Post subject: |
Do you want a list of every piece that was changed between the original and/or '77 model and the so-called "77.5" model? If so, I very much suspect you are S.O.L. and it doesn't exist.
With my first post, I answered both parts of your question in your first post, the conclusion being; You shouldn't really care.
But OK college kid, we'll hold your hand...
(the following definitely applies to U.S.-market cars but may be true of rest-of-the-world cars as well):
a) I know the original cars did not have fully galvanized bodies (if they were galvanized at all?). I am not 100% sure when this changed but to the best of my knowledge, my '81 is fully galvanized.
b) I know the original cars had lower-compression (i.e. less powerful) engines. I am reasonably sure the difference was in the pistons. To the best of my knowledge, the major 924 engine components are, generally speaking, fully interchangeable. There is certainly the odd different or updated part here or there over the years, especially the pistons and ignition system. But as I understand it, if you pull the head/manifolds/crank/pistons/cam/etc off one 924, it'll bolt right on to any other 924, regardless of year.
The BIG changes were made to the 924 Turbo and the 924S... the 924 Turbo has what is effectively a completely different engine and the 924S is almost a completely different car, just has the same body.
c) I know the 924 only had a four-speed or an automatic from introduction through the '78 model year. In fact, I don't the think the pre-"77.5" cars even had the option of an automatic. I'm not sure exactly when the five-speed became available. But I'm reasonably confident it was for the '79 model year.
If you want to know anything more than that, I think you'll have to find it yourself. You must appreciate that this 'board is a conglomeration of over a decade worth of conversation with no real structure. The Answer is most likely here. But you're most likely going to have to do some leg work to get it.
I get the feeling you have some modification in mind, and you'd like to know if it's even worth pursuing before you put any time/money into it? So, what is it, specifically? _________________ '80 924 Turbo |
Brendan
Posted: Thu Jan 27, 2011 1:10 pm Post subject: |
Ah, the internet, where every man is a king.
Thanks anyway, Khal. Maybe next time. |
Captain_Kirk
Posted: Thu Jan 27, 2011 1:50 pm Post subject: |
Dang. XH engine code on mine.
Didn't realize how low my vin was either 9247200155 _________________ 1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body |
Khal
Posted: Thu Jan 27, 2011 1:58 pm Post subject: |
| Brendan wrote: | | Ah, the internet, where every man is a king. |
Sorry, mate. No insult intended. Perhaps my sarcasm was poorly phrased. These types of forum are notorious for misunderstandings. The intended humour in a comment (and I did intend it to be humorous) is often not properly conveyed in plain text.
Hope there's no hard feelings. And good luck with your toofah. _________________ '80 924 Turbo |
CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Thu Jan 27, 2011 2:25 pm Post subject: |
We're a sarcastic bunch here, thick skin. Don't sweat it. I know that my 77' is slow, rusts and rusts faster than it accelerates.
But I love it. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Thu Jan 27, 2011 7:47 pm Post subject: |
The 77.5 was, IIRC, the first major revision to the car. But as is Porsche is wont to do, the revision was merely a sum of a lot of little things. For instance, I believe emissions controls only started appearing in the 77.5, depending on the marker. There was an extra resistor in the ignition circuit in the 76 that proved superfluous. The cabin fan gained an extra speed in later cars (from two to three). The centre console was added fairly early, perhaps as late as the 77.5. There were a few extra fuses from the 77.5 onwards; I think the horn might not have had one in the 76. The rear hatch didn't have its spoiler right at the start. I don't have my Haynes book here, so I'm guessing, I'm afraid, on all these. But it was all little things like that.
OTOH, things I do know for sure was that the manual boxes were all four speed until (I think) 1980. This was the same point that full body galvanising came in. Up until then, only the bottom half was. It should be noted that that model was a more major revision than the 77.5 one.
Wade. |
daniel
Posted: Sat Jan 29, 2011 8:05 am Post subject: |
My 77.5 has a dog leg 5 speed box
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Sat Jan 29, 2011 8:10 am Post subject: |
Theres a few hardcore types of a kind here thats for sure. Id
like to try a 4 spd. the dog-leg 5 is cool for highway driven. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
